DreamPlex - ein Plex Client für Enigma2
good job DonDavici, where are more skins? i have a vusolo and work really good
I just downloaded "enigma2-plugin-extensions-dreamplex_1.09_all.ipk" but it does not install.
can someone help me out with that?
@eiddi
did you restart e2?
greets
Wow great plugin thanks very much for the effort
but unfortunately subtitles doesn't seem to work on my dm800se
they don't show up in the subtitle list
is there anyway to make it work?
if it doesn't i think i'll just give using plex on samsung tv
but thanks anyway
when i try to install the .ipk file and it is done this it says
installing software...
done - installed, upgraded or uninstalled 0 packages (with 0 errors)
so nothing gets installed and yes I did reboot.
edit this is version 1.09
Direct Load Settings:
https://forums.plex.tv/topic/90021-direct-load-einstellung-dreamplex/?hl=%2Bdreambox+%2Bplugin
Great work DonDavici,thanks.
Unfortunately I have some green screens, could you please take a look at the attached crash log and advise?
dvbapp2_crash_1388686215.log (25.4 KB)
Thanks again.
Hi All
First of all great work on the app, it is a lot of work i presume and you always have people complaining if it does not work :)
My only question for you is: Does subtitles work when playing MKV files or not. What setting do i need to use, direct play or transcoded?  All work fine but i do not get the subtitle working. Using the latest Openpli and version 1.09 of Dreamplex. Also when i select TEXT button i get the Teletext app i do not presume that is correct right?
Thanks anyway.
menno
any news on channels?
Excellent work.  A very good plugin.  I have a VU+ solo2 running ViX and the Plexi skin is simply brilliant.
A couple of questions.
1.  I've added a couple of Plex Media Servers via " > DreamPlex > System > Server ".  What's the file path (I'm accessing over FTP) to edit the details of the Plex Servers I've added.  As I'd like to change some of the details e.g. the name
2.  The Movies load and browse really fast, however the TV shows are really slow.  Any suggestions?
3.  Is there a way to disable all artwork so the menu's run faster?
Many thanks
D
Is it possible to get this plugin to show  Plexchannels?
It would be a great addition to this great plugin and would limit the plugins in Enigma to just this one. At least for me it would give me everything besides the satellite channels I receive in the Engima box.
Jan
Hi all,
I really like this plugin, thank you to the devs for your work!
Could some one please tell me exactly where I can set the transcoding? I've been all over the settings, but didn't find anything related to transcoding...
Thanks,
Tom.
Hello, respect for this nice app:)
i have only one problem. the most BluRay Rips i tried to playing are without sound..
at a closer look i see that the problem occurs only with BD-Rips with DTS Sound. BD-Rips with AC3 are playing fine. but  all others with DTS there is no Sound, only Video :(
Is there any fix for that issue.
any news on an update?
very new 2.0 version with tons of new features and speedups is coming soon :slight_smile:
How about some little preview?
However, great work!!! The current one is already awesome!
Excellent news - I'm really looking forward to the update! The plexi-skin version looks absolutely amazing on my tv. I'm hoping there's going to be support for channels and iTunes in the new version but as had already been said it's already amazing as it is.
Just wanted to say many thanks for all your hard work on the best looking plex client by far.... it's very much appreciated here.
Hello all, I am hoping you can help with an issue i am having
I have recently installed DreamPlex 1.09.8 onto my Beyonnwiz T3 (enigma 2 machine), the installation went well and works like a charm thank you.When playing Mp4 and MKV files its perfect but i am having issues with AVI files.
The play back will stutter like dropping frames or something like that, i have played 5 different files and they all do the same.
Any ideas?
Thank you in advance
Any progress? Trying to wait patiently but it's been 2 weeks now! :rolleyes:
It's been a long month........no news yet?
