Hello,
I am running ubuntu 18.10 with plex media server Version 1.14.0.5470.
A while back. Chuck PA told me a way to get around the permissions issue, I had mounted my drive with my movies to
/home/media/Video_drive
and it worked perfectly for about a year
-I had to reformat my drive, its ext4
I remounted it using the disks app as above
then when I went to plex I could view all of the drives contents. Plex just shows the drive not the sub folders in it.
Ideas? wrong mount point
An input would be greatly appreciated
then remounting my drive, to no avail
I got it I left it mounted then it worked!.... thank you so much, so my media folder was blocking the permissions
everythings working now since i did that chmod on the media folder.
but for sake of interest my blkid is in the text file
not sure if changing my fstab is nessary, im kinda scared of doing that but yea Gnome must not like it but we found a workaround. So i think were ok.blkid.txt (110 Bytes)
Hello Chuck,
I did a few reboots and my plex is still able to see my drive sucessfully. So I think the prob is rectified. I will post over the next few days if theres an issue.
once runing chmod the directory permissions change regardless of reboot
Just so I entertain your idea correctly, can you give me step by step instructions on editing my fstab, as I have had no luck with this in the past.
Are you just asking I add this line for my drive, removing the old one
/dev/sdb1 /home/media/video_drive ext4 defaults,rw,auto 1 0
Secondly, I ran las -la on my mountpoint and here is my output, is this correct.
steve@steve-desktop:~$ ls -la /home/media/video_drive
total 36
drwxr-xr-x 6 steve steve 4096 Nov 28 22:55 .
drwxr-xr-x 6 root root 4096 Nov 28 21:10 ..
drwxr-xr-x 5 steve steve 4096 Nov 28 22:58 downloads_video_drive
drwxr-xr-x 2 root root 16384 Nov 28 18:20 lost+found
drwx------ 4 steve steve 4096 Nov 28 22:44 .Trash-1000
drwxr-xr-x 5 steve root 4096 Nov 28 21:55 Videos
