Hello! I am not able to find way to filter only D&B music and I don’t see it as track/artist/album genre. Only Electronic music but it’s obviously not exact. Can you do something with that? I can see more issues with this, not just D&B. Maybe also add BPM filter? it may help at least for now.
Don’t do that. Plex Music will only deliver very broad Genres, and use Style categories instead.
oh… okay… Now I have to re-scan 10TB library, wish me luck
Well, there’s 1 more issue. All my tracks are containing not usable genre info… I have tried Picard but it is causing more trouble than it helps as it wrongly match songs in folders as they are from other albums and show it as incomplete… Doing that manually is crazy amount of work considering it’s 10TB…
Then you will have to use the Style filter, instead of Genre.
There’s no DnB or other important styles, and there’s too many of them. I need something that can add genre to all tracks without messing with other tags or incorrectly match songs… Anyway, Plex should include that.
I have music sorted by “Artist/Album(year)/01. track.flac” maybe there’s some switch in Picard to include folder structure to match tracks? Each folder contain correct tracks from that album, even year is correct…
That’s quite perfect, don’t change that.
You can use software like Mp3tag - the universal Tag Editor (ID3v2, MP4, OGG, FLAC, ...) to read the folder structure and write information from there into meta tags.
However, the above folder structure doesn’t give a hint about genre either.
Exactly that’s the issue. I have no idea how to do it properly without errors
Do what exactly?
Well, match songs and add genre tag correctly without doing it manually. It will take years.
Then I’ll have to say that this is not something that Plex can do.
Well, to keep this suggestion, let this be about adding more genres to “Plex Music”
