Server Version#: 1.14.1.5488
Player Version#: 3.77.4
I just wanted to check-in with the group to understand expectations around the performance of a DS218+ and Live TV. I’m a long-time Plexpass subscriber who just recently grabbed a HDHomeRun Connect Duo when it went on sale. I only have two OTA channels available to me here in Nova Scotia but many of the shows we like to watch are aired on CTV.
So, I have a DS218+, and Live TV on CBC (720p broadcast) works fine, puts the CPU at about 25-30% CPU utilization. Live TV on CTV (1080i broadcast) is not watchable with pauses every 30 seconds or so. CPU utilization rises over 50%.
After performing other research here, I did confirm that I probably accidentally installed a 32-bit version of PMS on the Synology through the within Plex announced update downloads. Today I installed the latest 64-bit version from Plex’s website and the result is the same. Disabling HW transcoding results in the CPU being pegged at 99%.
So, will this configuration just not have enough power? Or might there be something else going on in my configuration.
Network isn’t an issue as MPEG2 streaming from the HDHomeRun to wireless iOS devices and wired clients is fine. It’s just when you throw Plex in the mix that CTV bogs down.
Any insights would be appreciated. I will happily provide log files if that would assist the troubleshooting process.
Thank you.
Jim
