DS718+ Server to Roku Express Buffer Issues
Newly set-up Plex server running on a Synology 718+ with hardware transcoding enabled. Streaming to a Roku Express on the same network. Seemed to work fine yesterday handling 1080p movies with subtitles. Today trying another 1080 movie and its buffering every few minutes. Yesterday it did not buffer at all. Attached log files, not sure if all 92 or so items were needed.
Server Version#: 1.13.8.5395
If providing server logs please do NOT turn on verbose logging
Moderator: Individual log files removed. Please use a .zip archive of the Logs directory in future.
Plex Media Server Logs_2018-10-19_07-24-11.zip (2.6 MB)
Doctor Who S01E01 XML.txt (3.6 KB)
Had to manually compress the log files, for some reason they seem to be auto unzipped when I download them. Thanks for the Help.
363.txt (91.9 KB)
Plex Media Server Logs_2018-10-19_18-26-24.zip (2.9 MB)
Does the same thing with this file, that I think is H.264 no subtitles and stereo audio. Also not really sure how the hardware acceleration works, but I kinda got the drift that it did the transcoding on the cpu connected to the server, in my case the NAS. I am monitoring the cpu usage and it stays around 5%.
Also does this on the web app in Safari.
@jaykster13
HW transcoding is available only for PlexPass holders.
If the CPU stays at 5%, you have a network issue.
Your logs show no HW transcoding is active. It is converting the audio for the Roku (expected)
Oct 18, 2018 21:50:31.602 [0x7ff28c847700] DEBUG - [Universal] Using local file path instead of URL: /volume1/Plex/Library/Application Support/Plex Media Server/Metadata/TV Shows/d/9fa107e9ea4500683b64e1b7c689cefe5f6f0a2.bundle/Contents/_combined/themes/com.plexapp.agents.plexthememusic_d62628b47c295179ddd073bd9a161999ff1cfd09
Oct 18, 2018 21:50:31.602 [0x7ff28c847700] DEBUG - TPU: hardware transcoding: final decoder: , final encoder:
Oct 18, 2018 21:50:31.606 [0x7ff28c847700] DEBUG - Job running: EAE_ROOT='/volume1/Plex/tmp_transcoding/pms-899631aa-1dbb-40a9-9019-e68235e84251/EasyAudioEncoder' FFMPEG_EXTERNAL_LIBS='/volume1/Plex/Library/Application\ Support/Plex\ Media\ Server/Codecs/e7828f1-1324-linux-ubuntu-x86_64/' XDG_CACHE_HOME='/volume1/Plex/Library/Application Support/Plex Media Server/Cache' XDG_DATA_HOME='/volume1/@appstore/Plex Media Server/Resources' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/volume1/@appstore/Plex Media Server/Plex Transcoder' '-codec:0' 'mp3' '-i' '/volume1/Plex/Library/Application Support/Plex Media Server/Metadata/TV Shows/d/9fa107e9ea4500683b64e1b7c689cefe5f6f0a2.bundle/Contents/_combined/themes/com.plexapp.agents.plexthememusic_d62628b47c295179ddd073bd9a161999ff1cfd09' '-filter_complex' '[0:0] aresample=async=1:ocl='\''stereo'\'':osr=44100:rematrix_volume=-25.000000dB[0]' '-map' '[0]' '-codec:0' 'libmp3lame' '-q:0' '0' '-f' 'segment' '-segment_format' 'mp3' '-segment_time' '1' '-segment_header_filename' 'header' '-segment_start_number' '0' '-segment_list' 'http://127.0.0.1:32400/video/:/transcode/session/e639739dfa6c69173cd4d09e405c9414/056a145d-2947-45cb-9356-0e5e60369a1f/seglist' '-segment_list_type' 'csv' '-segment_list_size' '2147483647' '-segment_list_separate_stream_times' '1' '-map_metadata' '-1' '-map_chapters' '-1' 'chunk-%05d' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/e639739dfa6c69173cd4d09e405c9414/056a145d-2947-45cb-9356-0e5e60369a1f/progress'
Oct 18, 2018 21:50:31.608 [0x7ff28c847700] DEBUG - Jobs: Starting child process with pid 16049
