DSM 7 USB Tuner
Server Version#: 1.23.4.4805
Tuner Make/Model: TV Butler
Guide/Lineup name:
Using XMLTV?:
On a spare diskstation 214 play I have i installed dsm 7 but as I feared it does not recognise the tv butler . Is there any hope or workaround ? If not I will need to stick to DSM 6 as long as I can…
Hi there. My main diskstation is the 218+ whoch works fine with plex. I am afraid to upgrade to DSM 7 as it says DSM 7 may not be able to use my usb tv butler tuner
Synology has removed USB tuner support from DSM 7.
The apparent only viable alternative is a network (TCP/IP) tuner.
