I have a Sonos system so I need all audio to be converted to AC3, this is no problem on PHT (Windows) but on my RPi2 I only get stereo.
If I play a AC3 movie i get full DD 5.1.
Yes, I have made sure only AC3 is ticked under settings as well as speaker setup is 5.1, I’ve also tried both 1.0.1 and 1.0.3 of Rasplex, both with same result.
Is the RPi 2 too slow? Do I need a RPi3 for this?
RPi2 is fine, this feature will be in the next release.
You need to activate “Enable Dolby Digital transcoding” in the audio output preferences.
See http://kodi.wiki/view/Audio_settings for an overview of all options, OpenPHT uses similar options.
“This option is only available where the number of channels is 2.0, for SPDIF this is set automatically so this option is always available, if using HDMI then you may need to change the Number of Channels setting to 2.0.”
