Server Version: 1.18.4.2171
Player Version: 7.25.2.14287
First, here’s my setup;
Server
PMS Version 1.18.4.2171
Client
PMP Version 7.25.2.14287
Firestick 4K
FireOS 6.2.6.8 NS6268/2315
Samsung UE46ES7000
Sonos Beam
Observation
When I play content that has an AC3 5.1 audio track everything plays fine, and the Sonos app shows Dolby Digital 5.1 as the source reaching the beam, so that part is working. However, when I play a file that has a DTS audio track (and yes, I know the Sonos doesn’t support DTS) then the Sonos reports as receiving a Dolby Digital 2.0 signal, so Plex is transcoding to 2.0 rather than 5.1.
Attempted Fix
The Firestick is the only Android device on our network, so I tried changing the Android.xml profile on the server to specify aac as support 6 channels (the default file read 2), but this had no effect (see excerpt below). I have come across reports that this is a firmware issue in the Firestick which causes the problem, but they all seem over a year old and I’m hoping (wishfully!) that something has been done about it in this time by either Amazon or Plex. Is there another way to force PMS to transcode from DTS to 5.1 and not 2.0? Or am I stuck converting all my DTS content to 5.1 on the server-side?
Android.xml profile changes
Original
<VideoAudioCodec name="aac">
<Limitations><UpperBound name="audio.channels" value="2" /></Limitations>
</VideoAudioCodec>
Modified
<Limitations><UpperBound name="audio.channels" value="6" /></Limitations>
</VideoAudioCodec>
