You can use the RaspberryPi B, B+ or RPi2. Obviously, the RPi2 is recommended.
If you have a TV that has the HDMI-CEC, you don’t need any additional remote, the TV remote will control Rasplex.
I’m not 100% sure about all your audio codec formats. I want to say “yes” to all of them in your list but not completely sure on the TrueHD. I’ve been using Rasplex for about a month so I haven’t completely dug through enough with audio pass through…
@jwaltrip4 said:
What code is RASPlex based on? PHT
Can I be skinned?
Best skin for Rasplex is Plex Black EditionHT by @DeadEyeFlint
Most of my movies are 5.1 AC3. I have a few DTS and TurHD movies. My AV reciver does the decoding. Any issues with RASPLEX for this?
DD(AC3), DD+(EAC3) and DTS no problem if you enable them as passthrough (capable receiver) in Preferences->System->Audio output, TrueHD will default to core DTS.
