Dune player
Sorry, link is ok now.
Thanks :D
Hi newloran2
I fined this section a bit confusing.
where do i fine the plex base url and do i include 32400?
“Edit File emplexer_config.php and set your plex base url in DEFAULT_PLEX constant (EX: http://192.168.2.9:32400) (sorry, this step is temporary).Reestart your Dune (stand by OK).A new folder named emplexer apear on plugin section”
I can not see the emplexer plugin after a reboot. Do I put the folders on the HD where my TV & movies are, or my main mackintosh hard drive?
Hi newloran2
I can’t get your software to work on my Dune HD base 3.0
Is it possible to post a step by step screen shots on how to install your software on github?
20mxm,
I work on better ilustrated documentation to emplexer.
In the nest commit to github i will post the installer to ( much mor easy to install :)).
Fow now see this screenshots:
**My Animes section filter: **
![post-72494-0-84577400-1353418905.jpg|690x388](upload://fOobW2h0ULiF2V57e4FYsGMGwsT.jpg)
**My Movies section filter: **
![post-72494-0-31899500-1353418977.jpg|690x388](upload://8hk91xcJg8r0nrqISMNgAPmz4U.jpg)
**The Tv_Show section with big thumbs and details: **
![post-72494-0-14088900-1353419137.jpg|690x388](upload://rE6LFan40AXv057h6iFvqHthH2.jpg)
**Movies section with big thumbs and no details: **
![post-72494-0-62784100-1353419347.jpg|690x388](upload://1nNhSCmAHIZvpr4V1hK3kg8yOgW.jpg)
Erik.
Thank you :smiley:
People,
I added a good step by step on how to install and use emplexer on GitHub https://github.com/newloran2/emplexer
Install package is now available in https://github.com/newloran2/emplexer/blob/master/dune_plugin_emplexer.zip?raw=true
Thaks to all.
Thanks Newloran2 :D
The software installed with ease!!!!
20mxm,
Good that it worked :).
Test the plugin at will and if possible tell me what you think, I'm open to suggestions for features :).
When browsing TV show episodes, there is no episode info. could you please add this feature,Basically it should work a bit more like the plex server menu
Great Plugin, as you stated no VIDEO_TS Streaming but BDMV works great, keep up the good job.
Yes, This plugin has great potential :smiley:
Thank's jaht,
I'm really glad that works with BDMV :), had not tested.
People,
new emplexer version on github https://github.com/newloran2/emplexer/blob/master/dune_plugin_emplexer.zip?raw=true
in this version all filters work much better and i kill much bugs.
Now image cache is enabled and turn second+ access much more fast :).
Thank’s 20mxm for your help.
Hi newloran2
Glad to help!!!
TV Episodes info
Can you please add episode/information for Tv series & films, in your next update.
with a nice GUI, similar to plex or your own design?
20mxm
20mxm,
j'll try, but don't expect so much, Dune api is very limited on gui components.
DuneX, zaptti and others make a nice wallpaper with image and description and use this on background, Dune don't have power to do this thing.
No problem, if the GUI stays the same :)
My main concern is the information about Tv episodes.
20mxm
Really glad to see plex on the dune. I am running my plex as an app on my qnap 459, to the dune using your plugin. It appears to work, but i think i have a small problem....
I have 3 collections the server, one is about 50 titles and other two somewhere around 300 each. I had just setup plex and it was still working on building the collection metadata when i tried to browse it from your plugin for the dune. I get error about not reading the xml list or something like that. The other 2 collections i let finish (took about 24 hrs for the qnap to process the art) and they seem to work. I dont really want to erase the collection inside of plex and have it scrape all over again, but it appears that is the fix. I tried deleting the dune plugin and reinstalling, but i get the same error.
I really like plex becuase it will auto scrape so i can just drag and drop files on to the server instead of having to run a script on my pc to build the xml files (zappiti, dune flash, etc)
I want the xbmc like feeling for the wife, without the constant labor of dune flash or zappati....plex seems to be closest thing i have found...i really dig that it runs on the qnap
Thank you so much for this. This is a very important tool for Dune players. I tried it and it works great with resume positions and stuff.
However, there is only one major thing missing, Subtitles. I tried with srt/txt subs inside MKV and outside MKV and this Dune client can not read/show subtitles.
Could you please add subtitle support? Subtitle is very important and unfortunately without subtitle support I can not use this Plex Dune app.
