Dune player
I got. the new hd pro 4k. Installing of dpc works, but could Not start or configure. Without DPC the Player is a Little bit worthless for me… But the new Dune Firm seems to be very stable so far.
Jmper, do you think it is possible to Port your awesome Plugin to new Dune Firmware ? Would be great!
BR
Peter
BR
Peter
+1 from me. Just got the new Dune pro 4K and it would be great if your wonderful plugin could be made to work on it!
BR
Peter
Please @jmpr! Add support for the new Dune Pro 4K ! :slight_smile:
are there any news about a “new” Version of this plugin? i also have a Dune pro 4K and want to use Plex…
new Version of the great Plugin would be awesome:-)
hi, i have a puzzling problem.
i have been using DPC installed into my Dune Smart D1, streaming from my Windows NAS. everything was working perfectly until a few days back. my system storage (USB) was failing (hardware) so i bought a new USB drive, inserted, configured and now, the DPC is installing fine, but will disappear after every restart of the Dune. i check system storage and it is present. i have to reinstall DPC again, all works well, but after another restart, DPC disappears again.
i have reset the Dune.
i have tried with another USB
i have tried with attaching a 2.5 inch drive as well.
problem remains.
anyone encountered anything like this before? any advise?
no response - i think dpc is dead - like yadis and other solutions - there are no answers from the programmer of dpc…
@jmpr: will there be a Version for 4KPro Version of the Dune Player? The 4kPro has no SystemStorage Function - DPC can’t run on the newest Dunes.
Hi and thanks for the plugin!
Since one or two PMS-Versions I don’t get any images/thumbnails on the dune. Has this problem anyone else?
WHS2011
Dune HD Smart
regards
