duplicate filter removed please tell me how i am suppose to check for duplicate movies on my server now. please help
I have it…
What versions you using?
for movies; click the ‘All’ drop down
The Duplicates filter is still there.
Are you trying this on a TV Shows-type library? If so, then you must switch the view mode to Episodes. Because only duplicate Episodes can be filtered, but not duplicate shows or seasons.
It’s in movies. Latest update, I can’t seem to locate it. Apologies if I am not looking in the right place.
Which client are you using?
Is this on your own server or one shared with you?
I no longer have the duplicate filter as well. I also am unable to use “Custom Filter” without an error. is there a fix for the duplicate filter missing?
Using Version 1.3.1.916-1cb2c34d
Update to v1.4 first. Then read above.
