Duplicates finder - sort duplicated movies (+matchind mode)
Ahoy,
Is in Plex function to show me what movies I have duplicated (different files names, but matched)?
Now I am using external software to finds duplicates, but even TornadoDuplicateCleaner what identify movies via frames / thumbnails CAN’T find all duplicates (but very most) - or can you tell me better app?
There is any matching mode for movies that plex can’t automatically detect?
  • now I sorted movies by not-matched and manually every files need to be clicked-matched… If you have more files named in foreign language (before Plex) this is exhausting.
So, lets see some friday night horror movie :laughing: :innocent:
You can filter your library by Duplicates
Edit: seems the post isn’t picking up my screenshot… here’s the related support article
https://support.plex.tv/articles/202393718-how-do-i-find-duplicate-or-merged-content/
Usually matching should work rather straight forward if you somewhat stick to the official naming schema… in particular for movies. You can insert a tag in the file/folder names to help Plex identifying an item (e.g. The Shawshank Redemption (1994) {tmdb-278} or The Shawshank Redemption (1994) {imdb-tt0111161}).
https://support.plex.tv/articles/naming-and-organizing-your-movie-media-files/
Similarly you can enter those terms in the title field when you manually fix-match an item inside Plex (e.g. tmdb-278 or imdb-tt0111161).
It shouldn’t really matter if your files are using a local title of a movie… IIRC Plex will also search for original titles and the title in the language you’ve set for your library.
Thanks a lot, I didn’t saw this before :sweat_smile:
Manual fix-matching would be great when the “creator” will be improved, for example - bigger window that show full long file name and make process more automatically (without need to click-by-click every single file, but shows not-matched movies in a row and just selecting proper match)
Again, thanks a lot, Your solution is very helpful :+1: :love_you_gesture:
