Duplicates that are not Duplicates
I have a lot of Mash episodes. I check for duplicates periodically. This morning I found a list of duplicates that are not duplicate. One of duplicate is from season 7 and the other is season 10.
What are the file names?
Look at the Get Info / Media Info for each problematic episode.
It will show the files Plex is considering to be duplicates.
Depending on what is shown, you can then take the appropriate action.
That’s where I am. It shows 2 different episodes.
Mail](Outlook) for Windows 10
Here is an example.
It appears that plex is seeing season 10 and 7 as the same season. The episodes are named with different seasons but same episode number. This was not a problem until today. Yesterday I updated server?
looking at the naming, you have one named simply MASH and the other named MASH (1972)
If I was you, I would remove them from the library. Rescan the library. Name them all correctly (use FileBot if necessary, you can get the free portable version out there still, no need to pay). Place them back into the library and rescan. It should pick them up. This would be the best and most proper way of doing things.
Question: Where does the library point for the series? To E:\? To E:\MASH?
If E:\, what else is in the directory? Hopefully no movies.
The usual structure would be E:\TV Shows\MASH\....., with the library pointing at TV Shows.
Basically, you cannot mix TV shows and movies in the same library. Also, the library must be the correct type, in this case, TV Show.
Suggestion: You should be able to split the shows. Using Plex Web, from the pre-play page click on the three dots, then choose “Split Apart.” I doubt this will work long term. Plex will probably re-combine them at some point when it re-scans the library.
Suggestion: Do a bit of cleanup on your directory names. For season 10, you put the year in the episode name. However, neither the show directory or other episode names contain the year. Either use the year or don’t. Plex likes consistency.
\MASH (1972)\Season 01\MASH (1972) - s01e01.mp4
or
\MASH\Season 01\MASH - s01e01.mp4
Suggestion: Verify and cleanup any embedded metadata in the files.
Examine the files with MediaInfo or look at the Plex XML info (click on View XML).
Make sure the show name, season, episode, etc are correct if present in the file.
If the show name is present, make sure it is M*A*S*H, not MASH.
Windows: MP3TAG
Mac: Subler
Suggestion: If none of the above works, change the search agent for the library from TheTVDB to The Movie Database. To change, edit the library, choose Advanced, then change the agent.
Reason: M*A*S*H might throw Plex for a curve. You cannot have * in a file or directory name, so you have to leave it out. However, if you search TheTVDB for 'MASH" it does not find the show. You have to search for M*A*S*H. On The Movie Database, you can search for ‘MASH’ and receive the correct information.
That’s everything I can think of right now. I suppose you could fall back to a prior version. If you want to do that, see this post.
how do i remove from library and not remove from external hard drive?
Bill
Move it to a location that is not scanned by Plex.
Hey guys.
Thanks for your help. Restructured folders. Got Filebot working. Got movies in separate folder.
Bill
Since I restructured my file system to separate movies, Quatro wants to record episodes already in my file system?
Bill
I don’t use the DVR capability in Plex, so can’t help you with that issue.
Hopefully somebody else can assist.
