Hi
not sure if im posting in the right place, but here goes.
i have a plex docker installed and running however when i try scan my usb tv card i get the following errors.
May 02, 2020 16:20:31.187 [0x1468e1ce2700] WARN - [E] dvb_channel_scanner_t::do_scan_attempt. Tune failed for 816500,7
May 02, 2020 16:20:31.252 [0x1468e1ae1700] WARN - [W] CV4lTunersStreamSrc::Start. pthread_setschedparam failed 1
if i install TVH plugin it works fine. so im not sure if its a permissions problem, a plex problem (the tuner works fine with plex in windows) or a docker problem.
any help would be great
im in Australia and know ill have to use XMLTV gor guid data (had it set up on windows)
thanks
Server Version#: 1.19.1.2701
Tuner Make/Model:
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
