I’ve just bought a HDHomeRun Connect, it’s working fine on its own. When integrating with Plex and selecting country and postcode, it only comes back with DVB-S/Satellite freesat/SKY channels and not DVB-T/T2 Freeview channels for UK. Do we know when these are going to be supported? i.e. when is Freeview DVB-T/T2 channel guides going to be available?
It’s OK, I’ve sorted it. It seems putting my full postcode in only comes up with DVB-S. Just putting the first half of it comes up with all options, including Freeview DVB-T. This is now resolved.
Where did you see freeview DVB-T? I only get YouView or Free to air as options
I used YouView. The EPG feed is just FreeView with a bit more metadata.
well it’s not quite. There are additional channels on YouView such as the sky channels and a few that are missing off of the EPG such as some +1 channels, BBC Red Button 0 etc
Yeah, it’s not bang on, but it seems to map correctly to the channels I watch at least. Better than nothing, I guess.
