Any DVB-S2 Tuners are Supported ? DVB-T and DVB-T2 is not realy used in Europe
DVB-S isn’t supported at the moment, but Plex are looking to expand support for different tuners in the future.
I have been using DVBS2 sucessfully with a setup of: tvheadend - tvhproxy - plex dvr
and in Enigma2 with my plugin, so if you have access to either of those options, you can try it.
Thanks i will try this.
I got enigma 2 Dreambox 500HD, i cant find hrtunerproxy in plugins feed. I exact plugin you are using. your little help will be grateful.
Is there any news on when or if DVBS2 tuners will be supported?
My HTPC is windows based and used to use DVB Player to make the tuners appear in Windows media center.
Are there similar methods to get them (2x Hauppage WinTv Nova-HD-S2) seen in plex?
