It should be noted that as of 1.1.1, there is no need for the fork of the theme music agent. The built-in agent now fetches theme music for shows imported using the dvd order agent.
I’m using 1.1.4.2757 and my DVDOrder imported shows have no theme music.
It is enabled and no music on either Firefly or Babylon 5.
@gbooker02 said:
You still need to enable it:
Settings → server → Agents → Shows → TheTVDBdvdorder → Plex Theme Music
as seen in:
BTW, I downloaded 1.1.4 fresh, installed the dvd order agent bundle, created fake media files for Firefly, imported it using the dvd order agent, and it had the theme music.
Wow, well this makes setting up new servers a bit less of a pain.
Any word on whether or not this feature is being looked into at all (as far as integration with plex natively)?
I can’t get the new agent to show up my server settings. I’ve put in the plugin folder (on macOS it’s ~/Library/Application Support/Plex Media Server/Plug-Ins) and restarted the server and it still doesn’t show up in the Agents section. I tried downloading a new agent from the Channel Directory to make sure it showed up the same place, and sure enough there it was. Deleting that one from the folder made it disappear from Settings, so it certainly seems like it should be working, but still no dice.
Never mind, tried from scratch again and it worked this time. Don’t know what I did wrong before.
Ok, so this worked for me (after much searching) It seems they have finally added this native. I am posting here because it is one of many places I searched for an answer.
Go to the Series, click Edit -> Advanced -> Episode Ordering -> DVD Order
Credit Roquemore92:
Hey guys, per Retrop7 suggestion, I found the “DVD ORDER” setting as he described March 2017, but the episodes still show up in the TV order format in Plex itself. Is there anyway to have it sort into the DVD order/seasons like the old plugin used to?
Go to the Series, click Edit → Advanced → Episode Ordering → DVD OrderCredit Roquemore92:
https://forums.plex.tv/discussion/226059/dvd-order-feature-request
