Thank you!!!!
thanks for keeping this alive CyberDave..
Can someone please quickly edit the bundle so we can have it predone for people?
Hopefully someone can update the bundle file with this fix and that others will find this information useful until that's done (I'd do it, but I'd have to jump through a bunch of hoops to comply with my work's open source contribution policy even for personal projects...if I have time and no one else steps up, I will).
Did a quick search/replace on __init__.py and zipped it up. It appears to be working like a charm! Tested it using Firefly and it correctly reordered the episodes.
Hmm, while the plugin appears to be working, I can't get Futurama seasons 5+ to work. Season 5 is supposed to the the four movies but instead it's the titles from season 6. Any ideas?
How do you install this in FreeNAS?
You'd extract the bundle from the latest zip file Viper compiled a few posts before yours, and place it in whatever folder Plex stores active channels in for FreeNas.
There's this wiki article that explains where it is for many common systems, including three *nix based that it would likely be similar to.
FreeNAS is linux, right? If you can't find it from looking at that article, you may want to search/ask in the Linux section of the server forum here.
Actually, FreeNAS is based on FreeBSD. Thanks for the link. I'll check it out.
I updated the DVDOrder Plugin with the version supplied by Viper007Bond above and it's working perfectly for some shows such as Firefly, but it won't pull the DVD Order for Astro Boy (both 1980/83 and 2003 versions), it only retrieves the Aired order.
Any instructions on how to install this plugin ? I need it for some TV Shows such as American Dad, i tried to unzip it into : C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins
But it doesn't show up, even after rebooting my computer.
Edit : I moved the folder into : C:\Users\Azsde\AppData\Local\Plex Media Server\Plug-ins and voilà. :)
Glad you found it, but for future reference for anyone else, see How do I manually install a channel? at the Plex Wiki, including the referenced 'see also' How do I find the Plug-Ins folder?
Thanks a ton for fixing. I made an attempt at fixing a few weeks back and failed miserably due to my lack of python skills. C# I could have handled. :)
Thanks to help here and on other threads, I've got it in the right folder for my QNAP ARM-based NAS. I also put the XML file in place I restarted but it still isn't showing up as an Agent. Is there something else I'm missing?
Update: I think I got it, although am just testing its accuracy with Firefly now. I think there was either a wrong folder involved, also under Plex Media Server/Plug-ins, so took more digging around to see another folder to try.
I've put the folder DVD Order Agent.bundle and contents in %USERPROFILE%\AppData\Local\Plex Media Server\Plug-ins
And restarted plex numerous times but my Firefly files are still messed up even after moving them in and out and reloading. It seems to keep taking from thetvdb only.
Shows Train Job first but the file is Serenity etc.
did you do a "fix incorrect match" and select "search option" then thedvdorder agent? or (or from the automatch dropdown)
And make sure you're using the latest greatest community member fixed bundle?
https://forums.plex.tv/topic/21141-dvd-order-agent/page-12#entry626550
Thanks a bunch. This really saved me. Finally my episodes are in the 'correct' order. :)
Great plugin thanks and seems to work a treat on Firefly!
you may have different DVDs than the ones thetvdb is using ( they are using the "volume" dvds not "season" ones) those movies are in the "specials" season according to thetvdb
http://thetvdb.com/index.php?tab=season&seriesid=73871&seasonid=103941&lid=7&order=dvd Season 6 is from volumes 5 and 6 which is what you are seeing.
Thanks for the great support all, got it going with no trouble at all!! :D
