Plex DVR is not scheduling any records or the Winter Olympics that start after midnight and before noon. My affiliate is KCRA (https://areyouwatchingthis.com/tv/stations/kcradt-nbc). I would suspect is not likely a data problem (Gracenote is not likely getting that wrong), So I suspect a bug in plex? Is there any way I can browse the full schedule, and/or manually add these recordings?
EDIT: Hmm. It may be detecting them as reruns. (maybe they are)
EDIT2: Yep, they are reruns. Issues solved.
