DVR File Sizes are too large
I’m using my Mac Pro 5,1 as a DVR. Has plenty of power but my 24TB of space is running out. I use the commercial removal tool and Transcode while recording is turned on. Is there a format that could save some space and if there is a format, is there a program for Mac. Especially one where I can just select the TV Shows folder and let it go to town.
Thank you
Normally I would suggest MCEBuddy - to ‘convert’ your big DRV files before they ever get to Plex. You’re on a Mac, so no can do.
Handbrake would do it, but you have to add each item to it’s Queue - after that the Queue just keeps going, and going, and going - until it runs out of stuff to do - or you add more to it.
There may be some other Mac solution.
I’m not a Mac Guy.
In your case Handbrake is a solution but not automated but you can queue
https://handbrake.fr/
I have used handbrake for DVDs what would be the best format to use?
Read original post, chenks.
For me mkv always
The format that Direct Plays on all your devices… let’s hope it’s MKVs.
This’ll get you started:
Adjust as required and fire for effect.
I knew what he meant.
Didn’t you?
Here we go again, yes we all know that
There something about the water today
Ok. This sounds like this is where I want to go. How do I go about post processing scripts?
