Using Windows version of Plex server and playing on Roku but issue is on the file. TV tuner is a supported Hauppauge USB stick tuner.
For the past few couple of years (since I switch from a Linux based server) whenever I record a show off the local Fox affiliate more often than not it either sets the SAP (descriptive in my area) as the primary audio channel or only records the SAP track.
I don’t mind changing the track to primary track if it’s there but it is rendering my shows useless when the SAP record.
I have seen people reporting this issue in the past but can’t see to find an update.
Is there anything I can do to eliminate the recording of SAP?
