DVR not recording
Server Version#: 1.21.1.3830
Tuner Make/Model: Haupage WinTV Dual HD
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
I would really love some help here. I don’t know how to get much of the information listed above.
I am using an Nvidia Shield Pro. I have my DVR set up and for a little while it was working well. Now every time I attempt to even watch a channel I get “Recording Failed: Live TV Session” and then “There was an error while attempting to tune the selected channel”. Things that I schedule to record almost never record.
I assumed it was a problem with the hard drive I had hooked up to the Shield to save the recordings, so I hooked up a different hard drive. No change.
I am happy to provide logs or anything else that might help but I don’t know what I should include.
Please help.
Here are some logs from my console that might relate to the problem:
Feb 03, 2021 19:43:25.472 [7980] Error — [Grabber/2.1-50080d7cce42924c-com-plexapp-android] Error parsing content.
Feb 03, 2021 19:43:25.472 [7980] Error — [Grabber/2.1-50080d7cce42924c-com-plexapp-android] Error parsing XML: Error parsing file.
Feb 03, 2021 19:43:25.472 [7980] Error — [Grabber/2.1-50080d7cce42924c-com-plexapp-android] Grabber: Error obtaining device status.
Feb 03, 2021 19:44:09.615 [7980] Debug — [Grabber/4.1-50080d7cce42924c-com-plexapp-android] Job running: EAE_ROOT=’/data/user/0/com.plexapp.mediaserver.smb/cache/pms-6bd63b5d-bc85-473c-a17a-da3563bbc8f7/EasyAudioEncoder’ FFMPEG_EXTERNAL_LIBS=’/data/user/0/com.plexapp.mediaserver.smb/Plex\ Media\ Server/Codecs/367b3d4-3654-android-aarch64/’ XDG_CACHE_HOME=’/storage/emulated/0/Android/data/com.plexapp.mediaserver.smb/cache’ XDG_DATA_HOME=’/data/user/0/com.plexapp.mediaserver.smb/Resources’ X_PLEX_TOKEN=‘xxxxxxxxxxxxxxxxxxxx’ ‘/data/user/0/com.plexapp.mediaserver.smb/Resources/Plex Transcoder’ ‘-noaccurate_seek’ ‘-ignore_unknown’ ‘-scan_all_pmts’ ‘-1’ ‘-rw_timeout’ ‘30000000’ ‘-reconnect’ ‘1’ ‘-reconnect_streamed’ ‘1’ ‘-reconnect_delay_max’ ‘30’ ‘-fflags’ ‘+discardcorruptts+fillwallclockdts’ ‘-probesize’ ‘20000000’ ‘-i’ ‘http://127.0.0.1:32600/devices/compound_device062dvb%23v4l%23%2Fsys%2Fdevices%2F70090000.xusb%2Fusb1%2F1-1%2F1-1%3A1.0%3A0014128579/media/triplet%3A%2F%2F0%3A291%3A3?param=<%3Fxml%20version%3D"1.0"%20encoding%3D"UTF-8"%3F> <tunedata><tt>8<%2Ftt><dq>0<%2Fdq><dr%2F><fr>36<%2Ffr><md>0<%2Fmd><sr>0<%2Fsr><pl>0<%2Fpl><lf>0<%2Flf><l1>0<%2Fl1><l2>0<%2Fl2><ls>0<%2Fls><pp>0<%2Fpp><hz>0<%2Fhz><in>0<%2Fin><fc>0<%2Ffc><t>291<%2Ft><n>0<%2Fn><s>3<%2Fs><en>0<%2Fen><%2Ftunedata> ’ ‘-map’ ‘0:V?’ ‘-codec:V’ ‘copy’ ‘-map’ ‘0:a?’ ‘-codec:a’ ‘copy’ ‘-map’ ‘0:s?’ ‘-codec:s’ ‘copy’ ‘-break_non_keyframes’ ‘1’ ‘-segment_format’ ‘mpegts’ ‘-f’ ‘ssegment’ ‘-individual_header_trailer’ ‘0’ ‘-segment_time’ ‘1’ ‘-segment_start_number’ ‘0’ ‘-segment_time_delta’ ‘0.25’ ‘-segment_list’ ‘http://127.0.0.1:32400/video/:/transcode/session/8b4d9867-2de3-47fd-8a74-8ac26d12c4a1/fd46742a-ed88-4925-90ae-9d21e77f35e4/seglist?X-Plex-Http-Pipeline=infinite’ ‘-segment_list_type’ ‘csv’ ‘-segment_list_size’ ‘5’ ‘-segment_list_separate_stream_times’ ‘1’ ‘-segment_list_unfinished’ ‘1’ ‘-max_delay’ ‘5000000’ ‘-map_metadata’ ‘-1’ ‘-map_chapters’ ‘-1’ ‘media-%05d.ts’ ‘-y’ ‘-nostats’ ‘-loglevel’ ‘quiet’ ‘-loglevel_plex’ ‘error’ ‘-xioerror’ ‘-progressurl’ ‘http://127.0.0.1:32400/video/:/transcode/session/8b4d9867-2de3-47fd-8a74-8ac26d12c4a1/fd46742a-ed88-4925-90ae-9d21e77f35e4/progress
Feb 03, 2021 19:44:09.615 [7980] Debug — [Grabber/4.1-50080d7cce42924c-com-plexapp-android] Job running: EAE_ROOT=’/data/user/0/com.plexapp.mediaserver.smb/cache/pms-6bd63b5d-bc85-473c-a17a-da3563bbc8f7/EasyAudioEncoder’ FFMPEG_EXTERNAL_LIBS=’/data/user/0/com.plexapp.mediaserver.smb/Plex\ Media\ Server/Codecs/367b3d4-3654-android-aarch64/’ XDG_CACHE_HOME=’/storage/emulated/0/Android/data/com.plexapp.mediaserver.smb/cache’ XDG_DATA_HOME=’/data/user/0/com.plexapp.mediaserver.smb/Resources’ X_PLEX_TOKEN=‘xxxxxxxxxxxxxxxxxxxx’ ‘/data/user/0/com.plexapp.mediaserver.smb/Resources/Plex Transcoder’ ‘-noaccurate_seek’ ‘-ignore_unknown’ ‘-scan_all_pmts’ ‘-1’ ‘-rw_timeout’ ‘30000000’ ‘-reconnect’ ‘1’ ‘-reconnect_streamed’ ‘1’ ‘-reconnect_delay_max’ ‘30’ ‘-fflags’ ‘+discardcorruptts+fillwallclockdts’ ‘-probesize’ ‘20000000’ ‘-i’ 'http://127.0.0.1:32600/devices/compound_device062dvb%23v4l%23%2Fsys%2Fdevices%2F70090000.xusb%2Fusb1%2F1-1%2F1-1%3A1.0%3A0014128579/media/triplet%3A%2F%2F0%3A291%3A3?param=<%3Fxml%20version%3D"1.0"%20encoding%3D"UTF-8"%3F> <tunedata><tt>8<%2Ftt><dq>0<%2Fdq><dr%2F><fr>36<%2Ffr><md>0<%2Fmd><sr>0<%2Fsr><pl>0<%2Fpl><lf>0<%2Flf><l1>0<%2Fl1><l2>0<%2Fl2><ls>0<%2Fls><pp>0<%2Fpp><hz>0<%2Fhz><in>0<%2Fin><fc>0<%2Ffc><t>291<%2Ft><n>0<%2Fn><s>3<%2Fs><en>0<%2Fen><%2Ftunedata> ’ ‘-map’ ‘0:V?’ ‘-codec:V’ ‘copy’ ‘-map’ ‘0:a?’ ‘-codec:a’ ‘copy’ ‘-map’ ‘0:s?’ ‘-codec:s’ ‘copy’ ‘-break_non_keyframes’ ‘1’ ‘-segment_format’ ‘mpegts’ ‘-f’ ‘ssegment’ ‘-individual_header_trailer’ ‘0’ ‘-segment_time’ ‘1’ ‘-segment_start_number’ ‘0’ ‘-segment_time_delta’ ‘0.25’ ‘-segment_list’ ‘http://127.0.0.1:32400/video/:/transcode/session/8b4d9867-2de3-47fd-8a74-8ac26d12c4a1/fd46742a-ed88-4925-90ae-9d21e77f35e4/seglist?X-Plex-Http-Pipeline=infinite’ ‘-segment_list_type’ ‘csv’ ‘-segment_list_size’ ‘5’ ‘-segment_list_separate_stream_times’ ‘1’ ‘-segment_list_unfinished’ ‘1’ ‘-max_delay’ ‘5000000’ ‘-map_metadata’ ‘-1’ ‘-map_chapters’ ‘-1’ ‘media-%05d.ts’ ‘-y’ ‘-nostats’ ‘-loglevel’ ‘quiet’ ‘-loglevel_plex’ ‘error’ ‘-xioerror’ ‘-progressurl’ ‘http://127.0.0.1:32400/video/:/transcode/session/8b4d9867-2de3-47fd-8a74-8ac26d12c4a1/fd46742a-ed88-4925-90ae-9d21e77f35e4/progress
Feb 03, 2021 19:44:12.763 [7980] Error — [Grabber/4.1-50080d7cce42924c-com-plexapp-android] Recorder: Error 16 (Recording failed. Please check your tuner or antenna.) starting the record, shutting things down.
Feb 03, 2021 19:44:12.763 [7980] Debug — [Grabber/4.1-50080d7cce42924c-com-plexapp-android] Grabber: Operation for ‘Live TV - Session 50080d7cce42924c-com-plexapp-android’ on channel 4.1 completed with status error (Recording failed. Please check your tuner or antenna.)
Some more error logs from today:
Feb 04, 2021 13:30:00.885 [31836] Error — [Grabber/7.1-9ff098f09c3352b1-com-plexapp-android/5ecd7dde1fadcd65c7652e06571d37801e5de500] Error issuing curl_easy_perform(handle): 7
Feb 04, 2021 13:30:00.886 [31836] Error — [Grabber/7.1-9ff098f09c3352b1-com-plexapp-android/5ecd7dde1fadcd65c7652e06571d37801e5de500] Error parsing content.
Feb 04, 2021 13:30:00.886 [31836] Error — [Grabber/7.1-9ff098f09c3352b1-com-plexapp-android/5ecd7dde1fadcd65c7652e06571d37801e5de500] Error parsing XML: Error parsing file.
Feb 04, 2021 13:30:00.886 [31836] Error — [Grabber/7.1-9ff098f09c3352b1-com-plexapp-android/5ecd7dde1fadcd65c7652e06571d37801e5de500] Grabber: Error obtaining device status.
Feb 04, 2021 13:30:00.907 [31287] Error — [Grabber/7.1-9ff098f09c3352b1-com-plexapp-android/5ecd7dde1fadcd65c7652e06571d37801e5de500] Unable to find title for item of type 5
Feb 04, 2021 13:30:01.316 [31252] Error — [Transcoder] [tcp @ 0x245a834300] Connection to tcp://127.0.0.1:32600 failed: Connection refused
Feb 04, 2021 13:30:01.316 [31252] Error — [Transcoder] http://127.0.0.1:32600/devices/compound_device062dvb%23v4l%23%2Fsys%2Fdevices%2F70090000.xusb%2Fusb1%2F1-1%2F1-1%3A1.0%3A0014128579/media/triplet%3A%2F%2F0%3A299%3A3?param=<%3Fxml%20version%3D"1.0"%20encoding%3D"UTF-8"%3F> <tunedata><tt>8<%2Ftt><dq>0<%2Fdq><dr%2F><fr>11<%2Ffr><md>0<%2Fmd><sr>0<%2Fsr><pl>0<%2Fpl><lf>0<%2Flf><l1>0<%2Fl1><l2>0<%2Fl2><ls>0<%2Fls><pp>0<%2Fpp><hz>0<%2Fhz><in>0<%2Fin><fc>0<%2Ffc><t>299<%2Ft><n>0<%2Fn><s>3<%2Fs><en>0<%2Fen><%2Ftunedata> : Connection refused
Feb 04, 2021 13:30:01.324 [31287] Error — [Grabber/7.1-9ff098f09c3352b1-com-plexapp-android/5ecd7dde1fadcd65c7652e06571d37801e5de500] Failed to start session.
Feb 04, 2021 13:30:01.324 [31287] Error — [Grabber/7.1-9ff098f09c3352b1-com-plexapp-android/5ecd7dde1fadcd65c7652e06571d37801e5de500] Recorder: Unable to create transcode session or session failed to start.
Feb 04, 2021 13:30:01.324 [31287] Error — [Grabber/7.1-9ff098f09c3352b1-com-plexapp-android/5ecd7dde1fadcd65c7652e06571d37801e5de500] Recorder: Error 16 (Recording failed. Please check your tuner or antenna.) starting the record, shutting things down.
Feb 04, 2021 13:30:01.325 [31287] Error — [Grabber/7.1-9ff098f09c3352b1-com-plexapp-android/5ecd7dde1fadcd65c7652e06571d37801e5de500] Starting media grab failed.
Feb 04, 2021 13:30:01.329 [31995] Error — Error issuing curl_easy_perform(handle): 7
Feb 04, 2021 13:30:01.330 [31995] Error — Error parsing content.
Feb 04, 2021 13:30:01.330 [31995] Error — Error parsing XML: Error parsing file.
Feb 04, 2021 13:30:01.330 [31995] Error — Grabber: Error obtaining device status.
I just restarted the Nvidia shield and these were the errors I received from the log as it booted back up:
Feb 04, 2021 13:52:50.410 [7614] Warning — Sync: local sync directory “/storage/emulated/0/Android/data/com.plexapp.mediaserver.smb/cache/Transcode/Sync+” does not exist
Feb 04, 2021 13:52:50.444 [6978] Error — Error issuing curl_easy_perform(handle): 7
Feb 04, 2021 13:52:50.444 [6978] Warning — HTTP error requesting GET https://142-129-86-22.57349cfb55e34f1b88d00766e5a34cc3.plex.direct:11686/identity (7, Couldn’t connect to server) (Failed to connect to 142-129-86-22.57349cfb55e34f1b88d00766e5a34cc3.plex.direct port 11686: Connection refused)
Feb 04, 2021 13:52:51.792 [7433] Warning — QueryParser: Invalid field ‘contentDirectoryID’ found, ignoring.
Feb 04, 2021 13:52:51.793 [7433] Warning — QueryParser: Invalid field ‘libraryHubsOnly’ found, ignoring.
Feb 04, 2021 13:52:52.208 [6973] Warning — MyPlex: attempted a reachability check but we’re not yet mapped.
Feb 04, 2021 13:52:55.350 [7577] Error — Error issuing curl_easy_perform(handle): 7
Feb 04, 2021 13:52:55.350 [7577] Warning — HTTP error requesting GET https://142-129-86-22.57349cfb55e34f1b88d00766e5a34cc3.plex.direct:11686/identity (7, Couldn’t connect to server) (Failed to connect to 142-129-86-22.57349cfb55e34f1b88d00766e5a34cc3.plex.direct port 11686: Connection refused)
Feb 04, 2021 13:52:55.981 [7408] Error — XML: Entity: line 1:
Feb 04, 2021 13:52:55.981 [7408] Error — XML: parser
Feb 04, 2021 13:52:55.981 [7408] Error — XML: error :
Feb 04, 2021 13:52:55.981 [7408] Error — XML: Start tag expected, ‘<’ not found
Feb 04, 2021 13:52:55.981 [7408] Error — XML: status=ok
Feb 04, 2021 13:52:55.981 [7408] Error — XML: ^
Feb 04, 2021 13:52:55.981 [7408] Error — Error parsing content.
Feb 04, 2021 13:52:55.982 [7408] Error — Error parsing XML: Error parsing file.
Feb 04, 2021 13:52:55.982 [7408] Error — SSDP: Error parsing device schema for http://192.168.86.55:9080
Feb 04, 2021 13:52:59.776 [7408] Error — XML: namespace
Feb 04, 2021 13:52:59.776 [7408] Error — XML: error :
Feb 04, 2021 13:52:59.776 [7408] Error — XML: xmlns:ms: ’ urn:microsoft-com:wmc-1-0’ is not a valid URI
Feb 04, 2021 13:52:59.776 [7408] Error — XML: xmlns:ms=" urn:microsoft-com:wmc-1-0"
Feb 04, 2021 13:52:59.776 [7408] Error — XML: ^
Feb 04, 2021 13:53:01.315 [7785] Error — Error issuing curl_easy_perform(handle): 7
Feb 04, 2021 13:53:01.316 [7785] Warning — HTTP error requesting GET https://142-129-86-22.b9d0be2de7f2419796f923ea0397fffb.plex.direct:32769 (7, Couldn’t connect to server) (Failed to connect to 142-129-86-22.b9d0be2de7f2419796f923ea0397fffb.plex.direct port 32769: Connection refused)
Feb 04, 2021 13:53:01.321 [7788] Error — Error issuing curl_easy_perform(handle): 7
Feb 04, 2021 13:53:01.321 [7788] Warning — HTTP error requesting GET https://142-129-86-22.78c0998efaca49b0908666f21896890c.plex.direct:21323 (7, Couldn’t connect to server) (Failed to connect to 142-129-86-22.78c0998efaca49b0908666f21896890c.plex.direct port 21323: Connection refused)
Feb 04, 2021 13:53:01.394 [7782] Error — Unknown metadata type:
Feb 04, 2021 13:53:01.405 [7783] Error — Unknown metadata type:
Feb 04, 2021 13:53:06.315 [7787] Error — Error issuing curl_easy_perform(handle): 28
Then I opened plex on my phone and attempted to watch a channel through Live TV DVR. I was able to successfully do so (I had not been able to do so before the restart) but I got these logs:
Feb 04, 2021 13:56:03.697 [7999] Error — [Grabber/7.1-9ff098f09c3352b1-com-plexapp-android] Unable to find title for item of type 5
Feb 04, 2021 13:56:06.385 [8004] Error — [Transcoder] [mpeg2video @ 0x22a0d5d500] Invalid frame dimensions 0x0.
Feb 04, 2021 13:56:06.386 [8004] Error — [Transcoder] [mpeg2video @ 0x22a0d5d500] Invalid frame dimensions 0x0.
Feb 04, 2021 13:56:06.387 [8004] Error — [Transcoder] [mpeg2video @ 0x22a0d5d500] Invalid frame dimensions 0x0.
Feb 04, 2021 13:56:06.388 [8004] Error — [Transcoder] [mpeg2video @ 0x22a0d5d500] Invalid frame dimensions 0x0.
Feb 04, 2021 13:56:06.389 [8004] Error — [Transcoder] [mpeg2video @ 0x22a0d5d500] Invalid frame dimensions 0x0.
Feb 04, 2021 13:56:06.390 [8004] Error — [Transcoder] [mpeg2video @ 0x22a0d5d500] Invalid frame dimensions 0x0.
Feb 04, 2021 13:56:06.391 [8004] Error — [Transcoder] [mpeg2video @ 0x22a0d5d500] Invalid frame dimensions 0x0.
Feb 04, 2021 13:56:06.392 [8004] Error — [Transcoder] [mpeg2video @ 0x22a0d5d500] Invalid frame dimensions 0x0.
Feb 04, 2021 13:56:06.393 [8004] Error — [Transcoder] [mpeg2video @ 0x22a0d5d500] Invalid frame dimensions 0x0.
Feb 04, 2021 13:56:06.394 [8004] Error — [Transcoder] [mpeg2video @ 0x22a0d5d500] Invalid frame dimensions 0x0.
Feb 04, 2021 13:56:06.396 [8004] Error — [Transcoder] [mpeg2video @ 0x22a0d5d500] Invalid frame dimensions 0x0.
Feb 04, 2021 13:56:26.158 [7427] Warning — SLOW QUERY: It took 990.000000 ms to retrieve 1 items.
Feb 04, 2021 13:56:26.237 [6974] Error — Session 0x26d3998818 terminated
Feb 04, 2021 13:56:26.395 [8023] Error — Unknown metadata type: folder
