DVR Playback issues
Server Version#: 1.18.7.2438
Player Version#: 4.21.2
Tuner Make/Model: Hdhr Prime HDHR3-CC
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
I’m not having issues with live playback, it is only on the recordings. It seems like in all scenarios, (transcode or not, and Comskip or not) Playback always creates and audio issue that can be as much as 2-3 seconds off from video. It has been going on for several server and player updates.
For non cut shows, the issue usually begins from the start, Jumping ahead in the show brings the audio closer in line, but never does sync. Now if you get further in the show then stop and restart within the video (not the beginning) It will play properly.
For cut shows, They start playing properly and continue to do so until the first cut section. Audio then begins to play behind the video. A skipping ahead fixes the issue, but skipping back only fixes the issue if you don’t go beyond a cut point.
