I love the new TV show “Ghosts”. When it started, I learned that it was based on a British show by the same name. I acquired three season of the British version, which is identified as “Ghosts (2019)” and the United States version is identified as “Ghosts (US)” or “Ghosts (2021)”. The problem that I have discovered is that when I set up for the show to be recorded OTA (here in the United States), is that it is saving them into the folder for “Ghosts (2019)”, the British version. I thought it odd when under the “TV Shows” that the British show was getting more episodes in the first season and then seeing that they were the US version. I’ve rectified this for already recorded episodes, moving them into the correct folder and then telling Plex to “Scan Library Files”. I pulled up scheduled episodes in the DVR and see that my only options is the TV base folder, not specifically the show’s proper folder. This tells me that until there is a fix made, I will have to manually move files after the DVR records for this particular show; annoying.
