DVR recording shows way earlier than it is supposed to
Hi, I’ve had this issue starting 2 weeks ago or so. I record the late show with steven colbert on weeknights… it’s always worked fine. now all of a sudden it seems to record over an hour earlier than it’s supposed to. when i play the recording it’s all the stuff that was on before. everything SEEMS to be setup correctly. wond it maybe be something to do with changing the clocks? is there a timezone setting to check someplace?
has anyone run into this before? I’m kind of lost on what to do. I deleted/recreated the dvr and same thing.
server runs on synology dsm 7
Server Version#: 1.26…0.5715-7000
Tuner Make/Model: HDHomeRun CONNECT QUATRO
Guide/Lineup name: not sure
Using XMLTV?: i don’t think so?
Channel number/Name: any
thanks,
Jim
I figured this out myself. the synology nas (where plex runs) was looking at a windows server for the time. the windows server had the wrong time (was off by an hour after the clock change). fixed all that, and now the nas shows the actual correct. I’m pretty confident that stuff will record properly now.
