Unfortuantely, I am back. The issue has resurfaced again for some reason.
My next step is to change the IP to 10.0.0.15
I’m also able to get a 10-0-0-15-xxxxx.plex.drect address and connect other docker containers to it (for example, tautulli) so I think that’s working correctly now?
I’ll monitor and see what happens from here, as I did see some interesting logs as playback of a local file (not live TV or DVR this time) stopped right around the timestamp where there was some network things logged. (deubg logging was off for htis one)
Plex w/ a local file had the error at about 5:49PM or just prior and here are the logs from that time frame.
Mar 08, 2025 17:47:20.329 [22985347181368] WARN - [Req#22/Transcode] Got a transcode session ping without a valid session ID.
Mar 08, 2025 17:47:21.641 [22985112857400] INFO - Refreshing paths watched by LibraryUpdateManager
Mar 08, 2025 17:47:28.374 [22985121413944] ERROR - Unknown metadata type:
Mar 08, 2025 17:47:28.382 [22985105759032] WARN - [Req#d9] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 17:47:28.383 [22985038515000] WARN - [Req#de] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 17:47:28.383 [22985101540152] WARN - [Req#db] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 17:47:28.383 [22985347181368] WARN - [Req#dd] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 17:47:28.383 [22985040624440] WARN - [Req#dc] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 17:47:28.383 [22985036405560] WARN - [Req#df] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 17:47:28.416 [22985063967544] ERROR - Unknown metadata type:
Mar 08, 2025 17:47:28.418 [22985347181368] WARN - [Req#dd] SLOW QUERY: It took 280.000000 ms to retrieve 6 items.
Mar 08, 2025 17:47:28.427 [22985036405560] WARN - [Req#df] SLOW QUERY: It took 380.000000 ms to retrieve 11 items.
Mar 08, 2025 17:47:28.482 [22985040624440] WARN - [Req#dc] SLOW QUERY: It took 870.000000 ms to retrieve 39 items.
Mar 08, 2025 17:47:28.527 [22985101540152] WARN - [Req#db] SLOW QUERY: It took 1230.000000 ms to retrieve 19 items.
Mar 08, 2025 17:47:28.738 [22985357974328] WARN - [CERT] TLS connection from 10.0.0.10:40270 came in with unrecognized plex.direct SNI name '10-0-0-10.cf320e351cde457a9b1afd1acb1446dd.plex.direct'; using installed plex.direct cert
Mar 08, 2025 17:47:28.925 [22985134136120] WARN - [HttpClient/HCl#44] HTTP error requesting GET https://10-0-0-10.cf320e351cde457a9b1afd1acb1446dd.plex.direct:32400 (60, SSL peer certificate or SSH remote key was not OK) (SSL: no alternative certificate subject name matches target host name '10-0-0-10.cf320e351cde457a9b1afd1acb1446dd.plex.direct')
Mar 08, 2025 17:47:29.372 [22985355864888] WARN - [CERT] TLS connection from 10.0.0.10:51168 came in with unrecognized plex.direct SNI name '172-18-0-1.0b583e932a864f3f98d4eb20ecfba74c.plex.direct'; using installed plex.direct cert
Mar 08, 2025 17:47:29.863 [22985134136120] WARN - [HttpClient/HCl#48] HTTP error requesting GET https://172-18-0-1.0b583e932a864f3f98d4eb20ecfba74c.plex.direct:32400 (60, SSL peer certificate or SSH remote key was not OK) (SSL: no alternative certificate subject name matches target host name '172-18-0-1.0b583e932a864f3f98d4eb20ecfba74c.plex.direct')
Mar 08, 2025 17:47:29.950 [22985129851704] ERROR - Unknown metadata type:
Mar 08, 2025 17:47:29.962 [22985072282424] WARN - [Req#110] Invalid library metadata ID plex://show/5fc69fafc2d465002df7bc29 passed.
Mar 08, 2025 17:47:29.963 [22985072282424] ERROR - downloadContainer: expected MediaContainer element, found html
Mar 08, 2025 17:47:29.963 [22985072282424] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fshow%2F5fc69fafc2d465002df7bc29
Mar 08, 2025 17:47:29.963 [22985072282424] ERROR - Subscription: Error refreshing sub: No container found
Mar 08, 2025 17:47:30.075 [22985362598712] ERROR - Unknown metadata type:
Mar 08, 2025 17:47:30.687 [22985136245560] ERROR - Unknown metadata type:
Mar 08, 2025 17:47:30.814 [22985061858104] ERROR - Unknown metadata type:
Mar 08, 2025 17:47:35.089 [22985034296120] WARN - [Req#1f7] QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Mar 08, 2025 17:47:35.457 [22985040624440] WARN - [Req#203] QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Mar 08, 2025 17:47:37.677 [22985061858104] ERROR - Unknown metadata type:
Mar 08, 2025 17:47:41.794 [22985061858104] ERROR - Unknown metadata type:
Mar 08, 2025 17:47:46.634 [22985061858104] ERROR - Unknown metadata type:
Mar 08, 2025 17:47:48.224 [22985061858104] ERROR - Unknown metadata type:
Mar 08, 2025 17:47:50.325 [22985105759032] WARN - [Req#21b/Transcode] Got a transcode session ping without a valid session ID.
Mar 08, 2025 17:48:20.329 [22985101540152] WARN - [Req#252/Transcode] Got a transcode session ping without a valid session ID.
Mar 08, 2025 17:48:43.373 [22985105759032] WARN - [Req#272/Transcode] Got a request to stop a transcode session without a valid session GUID.
Mar 08, 2025 17:49:24.883 [22985105759032] WARN - [Req#2c5/Transcode] Got a request to stop a transcode session without a valid session GUID.
Mar 08, 2025 17:49:24.920 [22985105759032] WARN - [Req#2d1] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Mar 08, 2025 17:49:24.920 [22985105759032] WARN - [Req#2d1] QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Mar 08, 2025 17:49:24.920 [22985105759032] WARN - [Req#2d1] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Mar 08, 2025 17:49:24.989 [22985129851704] WARN - [Req#2d7] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Mar 08, 2025 17:49:24.989 [22985129851704] WARN - [Req#2d7] QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Mar 08, 2025 17:49:24.989 [22985129851704] WARN - [Req#2d7] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Mar 08, 2025 17:49:25.032 [22985105759032] WARN - [Req#2d1] SLOW QUERY: It took 300.000000 ms to retrieve 50 items.
Mar 08, 2025 17:49:25.359 [22985121590072] WARN - [Req#2ed] QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Mar 08, 2025 17:49:32.927 [22985129851704] INFO - [Req#312/Transcode/1a21c65e5f1e35a8-com-plexapp-android] CodecManager: starting EAE at "/tmp/pms-b002e9f6-e115-45b5-b44b-67f0ffdde981/EasyAudioEncoder"
Mar 08, 2025 17:52:50.367 [22985105759032] INFO - [Req#84c] AutoUpdate: no updates available
Mar 08, 2025 17:57:40.225 [22985105759032] WARN - [Req#ea5] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 17:57:40.225 [22985347181368] WARN - [Req#ea7] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 17:57:40.227 [22985040624440] WARN - [Req#eab] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 17:57:40.227 [22985121590072] WARN - [Req#ea9] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 17:57:40.227 [22985129851704] WARN - [Req#eaa] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 17:57:40.231 [22985136245560] WARN - [Req#ea8] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 17:57:40.285 [22985136245560] WARN - [Req#ea8] SLOW QUERY: It took 280.000000 ms to retrieve 39 items.
Mar 08, 2025 17:57:40.286 [22985347181368] WARN - [Req#ea7] SLOW QUERY: It took 310.000000 ms to retrieve 19 items.
Mar 08, 2025 18:07:49.110 [22985036405560] WARN - [Req#1e11] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 18:07:49.111 [22985347181368] WARN - [Req#1e0f] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 18:07:49.112 [22985105759032] WARN - [Req#1e12] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 18:07:49.112 [22985040624440] WARN - [Req#1e13] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 18:07:49.116 [22985121590072] WARN - [Req#1e15] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 18:07:49.119 [22985038515000] WARN - [Req#1e14] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 18:07:49.168 [22985105759032] WARN - [Req#1e12] SLOW QUERY: It took 270.000000 ms to retrieve 39 items.
Mar 08, 2025 18:07:49.174 [22985036405560] WARN - [Req#1e11] SLOW QUERY: It took 300.000000 ms to retrieve 19 items.
Mar 08, 2025 18:07:50.468 [22985129851704] INFO - [Req#1e1c] AutoUpdate: no updates available
Mar 08, 2025 18:17:30.844 [22985364708152] WARN - JobManager: Could not find job for handle 13621
Mar 08, 2025 18:17:58.027 [22985038515000] WARN - [Req#2b67] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 18:17:58.029 [22985136245560] WARN - [Req#2b6b] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 18:17:58.029 [22985121590072] WARN - [Req#2b6d] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 18:17:58.030 [22985036405560] WARN - [Req#2b6a] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 18:17:58.046 [22985347181368] WARN - [Req#2b69] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 18:17:58.047 [22985129851704] WARN - [Req#2b6c] Missing X-Plex-Container-Size header. This will fail with status code 400 in the future.
Mar 08, 2025 18:17:58.077 [22985036405560] WARN - [Req#2b6a] SLOW QUERY: It took 240.000000 ms to retrieve 39 items.
Mar 08, 2025 18:17:58.115 [22985347181368] WARN - [Req#2b69] SLOW QUERY: It took 320.000000 ms to retrieve 19 items.
Mar 08, 2025 18:22:50.389 [22985136245560] INFO - [Req#31b8] AutoUpdate: no updates available
