Server Version#: 1.20.3.3437
Player Version#: N?A
Tuner Make/Model:
Guide/Lineup name: HeeHaw
Using XMLTV?:
Channel number/Name: 19.3 Dayton Circle GRIT
When recording TV shows its creating a Season2020 folder in the show folder instead of the actual season information. This seems to be coming from the EPG data which is not including the episode or season info and just the current air date it was just aired on. Is there any fix for this? This happens with most of the old shows on stations that are reairing shows. Is there anyway to see the EPG data plex sees for shows or correct it?
Example:
Hee Haw (1969)/Season 2020/Hee Haw (1969) - 2020-10-16 08 00 00 - Johnny Cash.mkv
This should be Season 18 ep 7 I beleive from what i can see
