DVR Setup hanging
Not sure what the issue is here. I’ve tried a few times…once by checking all boxes for all channels…and then a second time with a select few…it just sits here after clicking Continue!!
I just posted the same issue. Have you found a solution? Mine is a WinTV dualHD tuner running on win10
Happened to me when I was setting up on Friday. Messed with it for a couple hours and just gave up. Win 10, 64-bit. HDHomerun Quatro.
Without this step there is no way to install the tuner in Plex, right?
Looks like a bug. I rolled back to 1.10.1.4602 and it works fine
Just wanted to chime in and say I also re-installed 1.10.1.4602 and it hangs on this version for me as well!
I have same problem, dvr setup just hangs at the program guide so no tv.
I have hauppage WinTV dualHD tuner
Trying to connect to any tv guude in UK just doesnt work.
I get perfect signal with the tuners own software so this is a problem with plex.
Probably going to cancel plex pass and certainly not recommending it, complete waste of time.
Very disappointed.
