DVR unable to schedule recordings- "No write access to destination" Big yellow triangle
Set up is on a Windows 11 install - AMD Ryzen 6 processor
Server Version#: 1.40.1.8227
Player Version#: N/A
Tuner Make/Model:
HDHomeRun FLEX 4K
Model: HDFX-4K
Device ID: Removed
Firmware: 20231214
Guide/Lineup name:
Using XMLTV?: No
Channel number/Name: ALL
Unable to schedule recordings. As the error “No write access to destination” Big yellow triangle.
Research leads me to here: C:\Users"Username"\AppData\Local\PlexMediaSever\Scrips
The folder has “Read” only marked.
Checked: Path to a program which postprocesses the recording before adding to the library. The script must be in “C:\Users"Username”\AppData\Local\Plex Media Server\Scripts"
Also found this in the logs:
Apr 14, 2024 16:45:02.782 [5952] INFO - Plex Tuner Service v1.40.1.8227-c0dd5a73e - Microsoft PC x64-x64 - build:
Apr 14, 2024 16:45:02.782 [5952] INFO - Windows version: 6.2 (Build 9200), language en-US
Apr 14, 2024 16:45:02.782 [5952] INFO - 12 3600 MHz processor(s): Architecture=9, Level=23, Revision=2050 Processor Identifier=AMD64 Family 23 Model 8 Stepping 2, AuthenticAMD
Apr 14, 2024 16:45:02.782 [5952] DEBUG - “C:\Program Files\Plex\Plex Media Server\Plex Tuner Service.exe” “C:\Program Files\Plex\Plex Media Server\Resources\Tuner\Private” “C:\Program Files\Plex\Plex Media Server\Resources\Tuner\Shared” 1.40.1.8227-c0dd5a73e 32600
Apr 14, 2024 16:45:02.775 [13020] INFO - [I] broker_t::start…
Apr 14, 2024 16:45:02.928 [13020] INFO - [I] device_manager_t::init.
Apr 14, 2024 16:45:02.928 [13020] INFO - [I] device_manager_t::init. Initialize provider manager
Apr 14, 2024 16:45:02.928 [13020] INFO - [I] device_manager_t::init. Initialize all device auxes
Apr 14, 2024 16:45:02.928 [13020] INFO - [I] dvb_device_factory_t::get_aux_list
Apr 14, 2024 16:45:02.928 [13020] INFO - [I] bda_aux_t::init
Apr 14, 2024 16:45:02.933 [13020] INFO - [I] web_server_t::start. Starting web server on port 32600
Apr 14, 2024 16:45:15.495 [2680] INFO - [I] web_service_t::process_device_discovery
Apr 14, 2024 16:45:15.495 [2680] INFO - [I] device_reactor_t::get_device_list ()
Apr 14, 2024 16:45:17.547 [2680] INFO - [I] SAT2IP - discover_satip_servers(): no servers found
Apr 14, 2024 16:45:17.978 [13512] WARN - [E] enum_create(): Class not found, CreateClassEnumerator returned S_FALSE
Apr 14, 2024 16:45:17.978 [13512] INFO - [I] DeviceGetListEx_impl: pDL->Count:0
Apr 14, 2024 16:45:17.978 [2680] DEBUG - [I] file_tuner::get_stream_file. File C:\Program Files\Plex\Plex Media Server\Resources\Tuner\Private\devices\dvb\file\drv_file.ini does not exist
Been running PLEX for a few years now. Recently removed from my WD Raided drive as the performance was less than I expected and had a few play back issues (CPU performance).
I have always sorted out any issue with the install before - but this one is stumping me. I suspect the either the “drv_file.ini” needs to be rebuilt/installed (how) or the read only permissions need some custom edit for write but details matter and not sure what to edit for “C:\Users"Username”\AppData\Local\Plex Media Server\Scripts"
I’ve been having the same issue on my ubuntu install! I’ve tried everything from using external storage and making sure plex is the owner of the directories (which was more difficult than I realized at first because my external drive is in exFAT and not ext4) - to just creating a special directory for it on the main drive, and ensuring it has the plex ownership as well as the rwxrwxr-x set of permissions. Still my recordings failed and I’m unsure as to why at this point. I found some help in this post:
https://www.reddit.com/r/PleX/comments/1599nkw/setting_up_dvr_for_the_first_time_and_getting_no/
But none of those solutions worked for me. I must be doing something wrong, I just wish I knew what lol. Maybe the next update and will fix?
