DVR Useless: Recorded shows do not play
It looks like the so called ‘investigation’ didn’t go so well @ChuckPa (Transcoder Crashing When Converting To AAC (bad block)). An issue from 2019 is still exists in 2023 and now affects more than half of my recorded shows. That and the fact that if I to turn off subtitles or the locally played video will buffer…
It seems like they left the DVR functionality to an Intern.
  • Record a show.
  • Play the show…
  • Error, cannot play.
Jul 28, 2023 04:50:33.699 [198347652288] DEBUG - [Req#e20d8/Transcode/4e7bfe204188c6b5-com-plexapp-android/JobRunner] Job running: FFMPEG_EXTERNAL_LIBS=‘/data/user/0/com.plexapp.mediaserver.smb/Plex\ Media\ Server/Codecs/8217c1c-4578-android-aarch64/’ X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx “/data/app/~~FHZd3BQD6HOdM2JGwF8CTg==/com.plexapp.mediaserver.smb-eeQQGn7WgKO_jmRESvZZJw==/lib/arm64/libPlexTranscoder.so” “-codec:#0x100” mpeg2video -noaccurate_seek -analyzeduration 20000000 -probesize 20000000 -i “/sdcard/TV Shows/NOVA (1974)/Season 46/NOVA (1974) - S46E14 - The Planets Jupiter.ts” -map “0:#0x100” -codec:0 copy -map “0:#0x101” -metadata:s:1 language=eng -codec:1 copy -segment_format matroska -f ssegment -individual_header_trailer 0 -flags +global_header -segment_header_filename header -segment_time 10 -segment_start_number 0 -segment_copyts 1 -segment_time_delta 0.0625 -segment_list “http://127.0.0.1:32400/video/:/transcode/session/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e/manifest?X-Plex-Http-Pipeline=infinite” -segment_list_type csv -segment_list_size 5 -segment_list_separate_stream_times 1 -segment_list_unfinished 1 -segment_format_options output_ts_offset=10 -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 “media-%05d.ts” -start_at_zero -copyts -vsync cfr -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e/progress
Jul 28, 2023 04:50:33.699 [198347652288] DEBUG - [Req#e20d8/Transcode/4e7bfe204188c6b5-com-plexapp-android/JobRunner] In directory: “/storage/emulated/0/Android/data/com.plexapp.mediaserver.smb/cache/Transcode/Sessions/plex-transcode-4e7bfe204188c6b5-com-plexapp-android-dac6e097-4f8a-457e-8f93-5fdb8ec2a10e”
Jul 28, 2023 04:50:33.701 [198347652288] DEBUG - [Req#e20d8/Transcode/4e7bfe204188c6b5-com-plexapp-android/JobRunner] Jobs: Starting child process with pid 23157
Jul 28, 2023 04:50:33.811 [198349733056] DEBUG - Request: [127.0.0.1:37474 (Loopback)] PUT /video/:/transcode/session/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e/progress?status=startup (15 live) #e20ce Signed-in Token (Dzeff) (range: bytes=0-)
Jul 28, 2023 04:50:33.812 [198485277888] DEBUG - Completed: [127.0.0.1:37474] 204 PUT /video/:/transcode/session/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e/progress?status=startup (15 live) #e20ce 0ms 203 bytes (pipelined: 1) (range: bytes=0-)
Jul 28, 2023 04:50:33.821 [198346611904] DEBUG - Request: [127.0.0.1:37474 (Loopback)] PUT /video/:/transcode/session/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e/progress?status=startup (15 live) #e20da Signed-in Token (Dzeff) (range: bytes=0-)
Jul 28, 2023 04:50:33.822 [198486318272] DEBUG - Completed: [127.0.0.1:37474] 204 PUT /video/:/transcode/session/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e/progress?status=startup (15 live) #e20da 0ms 203 bytes (pipelined: 2) (range: bytes=0-)
Jul 28, 2023 04:50:33.822 [198349733056] DEBUG - Request: [127.0.0.1:37474 (Loopback)] PUT /video/:/transcode/session/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e/progress?status=opening (15 live) #e20db Signed-in Token (Dzeff) (range: bytes=0-)
Jul 28, 2023 04:50:33.823 [198486318272] DEBUG - Completed: [127.0.0.1:37474] 204 PUT /video/:/transcode/session/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e/progress?status=opening (15 live) #e20db 0ms 203 bytes (pipelined: 3) (range: bytes=0-)
Jul 28, 2023 04:50:33.826 [198346611904] DEBUG - Request: [127.0.0.1:37474 (Loopback)] PUT /video/:/transcode/session/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e/progress?status=opened (15 live) #e20dc Signed-in Token (Dzeff) (range: bytes=0-)
Jul 28, 2023 04:50:33.827 [198485277888] DEBUG - Completed: [127.0.0.1:37474] 204 PUT /video/:/transcode/session/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e/progress?status=opened (15 live) #e20dc 0ms 203 bytes (pipelined: 4) (range: bytes=0-)
Jul 28, 2023 04:50:33.827 [198349733056] DEBUG - Request: [127.0.0.1:37474 (Loopback)] PUT /video/:/transcode/session/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e/progress/stream?index=0&id=256&codec=mpeg2video&type=video (15 live) #e20dd Signed-in Token (Dzeff) (range: bytes=0-)
Jul 28, 2023 04:50:33.828 [198486318272] DEBUG - Completed: [127.0.0.1:37474] 200 PUT /video/:/transcode/session/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e/progress/stream?index=0&id=256&codec=mpeg2video&type=video (15 live) #e20dd 0ms 195 bytes (pipelined: 5) (range: bytes=0-)
Jul 28, 2023 04:50:33.828 [198346611904] DEBUG - Request: [127.0.0.1:37474 (Loopback)] PUT /video/:/transcode/session/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e/progress/stream?index=1&id=257&codec=ac3&type=audio (15 live) #e20de Signed-in Token (Dzeff) (range: bytes=0-)
Jul 28, 2023 04:50:33.829 [198486318272] DEBUG - Completed: [127.0.0.1:37474] 200 PUT /video/:/transcode/session/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e/progress/stream?index=1&id=257&codec=ac3&type=audio (15 live) #e20de 0ms 195 bytes (pipelined: 6) (range: bytes=0-)
Jul 28, 2023 04:50:33.829 [198349733056] DEBUG - Request: [127.0.0.1:37474 (Loopback)] PUT /video/:/transcode/session/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e/progress/stream?index=2&id=258&codec=ac3&type=audio (15 live) #e20df Signed-in Token (Dzeff) (range: bytes=0-)
Jul 28, 2023 04:50:33.830 [198486318272] DEBUG - Completed: [127.0.0.1:37474] 200 PUT /video/:/transcode/session/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e/progress/stream?index=2&id=258&codec=ac3&type=audio (15 live) #e20df 0ms 195 bytes (pipelined: 7) (range: bytes=0-)
Jul 28, 2023 04:50:33.832 [198346611904] ERROR - [Req#e20e0/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [ac3 @ 0x2e4b984650] new coupling strategy must be present in block 0
Jul 28, 2023 04:50:33.833 [198349733056] ERROR - [Req#e20e1/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [ac3 @ 0x2e4b984650] error decoding the audio block
Jul 28, 2023 04:50:33.834 [198346611904] ERROR - [Req#e20e2/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [ac3 @ 0x2e4b9830c0] expacc 127 is out-of-range
Jul 28, 2023 04:50:33.835 [198349733056] ERROR - [Req#e20e3/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [ac3 @ 0x2e4b9830c0] error decoding the audio block
Jul 28, 2023 04:50:33.836 [198346611904] ERROR - [Req#e20e4/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [mpeg2video @ 0x2e4b9809f0] Invalid frame dimensions 0x0.
Jul 28, 2023 04:50:33.837 [198349733056] ERROR - [Req#e20e5/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [mpeg2video @ 0x2e4b9809f0] Invalid frame dimensions 0x0.
Jul 28, 2023 04:50:33.838 [198346611904] ERROR - [Req#e20e6/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [mpeg2video @ 0x2e4b9809f0] Invalid frame dimensions 0x0.
Jul 28, 2023 04:50:33.839 [198349733056] ERROR - [Req#e20e7/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [mpeg2video @ 0x2e4b9809f0] Invalid frame dimensions 0x0.
Jul 28, 2023 04:50:33.839 [198346611904] ERROR - [Req#e20e8/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [mpeg2video @ 0x2e4b9809f0] Invalid frame dimensions 0x0.
Jul 28, 2023 04:50:33.841 [198349733056] ERROR - [Req#e20e9/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [mpeg2video @ 0x2e4b9809f0] Invalid frame dimensions 0x0.
Jul 28, 2023 04:50:33.842 [198346611904] ERROR - [Req#e20ea/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [mpeg2video @ 0x2e4b9809f0] Invalid frame dimensions 0x0.
Jul 28, 2023 04:50:33.843 [198349733056] ERROR - [Req#e20eb/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [mpeg2video @ 0x2e4b9809f0] Invalid frame dimensions 0x0.
Jul 28, 2023 04:50:33.844 [198346611904] ERROR - [Req#e20ec/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [mpeg2video @ 0x2e4b9809f0] Invalid frame dimensions 0x0.
Jul 28, 2023 04:50:33.846 [198349733056] ERROR - [Req#e20ed/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [mpeg2video @ 0x2e4b9809f0] Invalid frame dimensions 0x0.
Jul 28, 2023 04:50:33.847 [198346611904] ERROR - [Req#e20ee/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [mpeg2video @ 0x2e4b9809f0] Invalid frame dimensions 0x0.
Jul 28, 2023 04:50:33.848 [198349733056] ERROR - [Req#e20ef/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [mpeg2video @ 0x2e4b9809f0] Invalid frame dimensions 0x0.
Jul 28, 2023 04:50:33.848 [198346611904] ERROR - [Req#e20f0/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [mpeg2video @ 0x2e4b9809f0] Invalid frame dimensions 0x0.
Jul 28, 2023 04:50:33.849 [198349733056] ERROR - [Req#e20f1/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [mpeg2video @ 0x2e4b9809f0] Invalid frame dimensions 0x0.
Jul 28, 2023 04:50:33.850 [198346611904] ERROR - [Req#e20f2/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [mpeg2video @ 0x2e4b9809f0] Invalid frame dimensions 0x0.
Jul 28, 2023 04:50:33.850 [198349733056] ERROR - [Req#e20f3/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [mpeg2video @ 0x2e4b9809f0] Invalid frame dimensions 0x0.
Jul 28, 2023 04:50:33.851 [198346611904] ERROR - [Req#e20f4/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [mpeg2video @ 0x2e4b9809f0] Invalid frame dimensions 0x0.
Jul 28, 2023 04:50:33.852 [198349733056] ERROR - [Req#e20f5/Transcode/4e7bfe204188c6b5-com-plexapp-android/dac6e097-4f8a-457e-8f93-5fdb8ec2a10e] [mpeg2video @ 0x2e4b9809f0] Invalid frame dimensions 0x0.
Server Version#: 1.32.5.7349
Player Version#: 4.111.1
Tuner Make/Model: WinTV-dualHD
Guide/Lineup name: don’t know where to find this.
Using XMLTV?: No
Channel number/Name:
