Server Version#: 1.14.1.5488
Good morning, I currently have a DS214play. I’m running out of space on both 4TB discs each, so I bought a new Synology DS418play with two 10TB discs. The maximum supported by the DS214play is 4TB per disk.
I have been reading the options to migrate the Plex database (Migrate metadata from one Synology NAS to another), and I have some doubts. When I get in touch with the Synology technical service, they tell me that in order to migrate everything to a new NAS, I have to insert the two 10TB disks in the new NAS, update the system, and copy and paste the data using File Station-> Tools -> Mount Remote Folder. This allows me to mount folders from one NAS to another. But they add “Unfortunately, Plex is third party software not developed by Synology, we can not support moving the data base to the new nas or have any info on how to do such”, therefore I do not know if this system would work not to lose the database.
I do not know if it would work to clone each 4TB disc on the 10TB discs and add them to the new Synology DS418play.
Is it possible to mount a RAID on the new Synology and run the database? That is, do the movies copied to the new server have to be exactly on the same route on the two servers?
Sorry if I repeat issues already mentioned in the forum, but I am not clear about some issues and I do not want to lose my database, since it has many hours of work, I am a mess.
Thank you,
Fran.
