Edit don't work anymore in all library/movies
Hi all, today after i moved some sd files from some fullhd folders the edit feature stopped to work.
Here the result for all movies.
Do you have any suggestion?
The dashboard show this :frowning:
The movies having an issue after moving some files could be something basic but if your dashboard results are empty there’s something else going on.
Does the dashboard remain totally empty or it just loads slowly?
I would post your server version number and add your log files here so when an employee shows up it’s ready. Might save some time
Logs are in the troubleshooting section down at the bottom in the settings
Hi JaysPlex7. Thanks for the fast answer:
It don’t load slowly. Is stuck.
Here my version and logs.
Plex Media Server Logs_2022-08-29_22-35-44.zip (370.1 KB)
Ok I’m not very experienced in reading logs but i do see a lot of this
Screenshot (2246)
And this
Screenshot (2247)
That looks odd to me but I really don’t know.
I don’t see anything that says corrupt or malformed so I don’t “think” this is a corrupt database.
You’ll have to wait for someone who knows what they’re doing unfortunately LOL
Ok, thanks :slight_smile:
I resolved! Was the Plex on Firefox that produce problems. I just tried the Plex Player and inside it all work as expected. So it’s related to the browser at this time.
Thanks again for your time :slight_smile:
