I just noticed that Blade Runner was showing up twice in my Science Fiction Library, as were several other movies. After much frustration I realized it was due to a “feature” not a bug called collections. A feature that I hate, by the way. Anyway, I had to edit every library to turn that feature off, and it would have saved me a lot of time if I could have just globally turned off that feature or edited all the libraries at once.
+1
Library parameters should be made available for bulk edition (either through the interface or via xml/json/ini/whatever export/import).
