Embedded Subtitles in MP4 file not working
I have been reading/searchin gthrough the forum but did not find the same problem I am having. If I have missed it, please point me in the right direction and I will close this discussion. I apologize in advance if this is the wrong area.
I am using Plex Media Server 1.0.3.2461, and latest clients on Windows(Plex HTML5 Web Player), iPhone 6S, iPhone 6S Plus, iPad Air 2, AppleTv4, Samsung Galaxy Note 3, Samsung Galaxy Note 4 and Samsung TV. I watch on the devices directly or sometimes use a phone to cast to a Chromecast.
The issue I am having since ~June, is that embedded subtitles stopped working across all devices exept iPhone, iPad and Apple TV4. The subtitles on all other devices are appear as black colored on the top of the screen with a very big font. (On the Samsung TV it says 30 px). The subtitle options on the plex clients have only effect on font size, but not on placement or color of the subtitles.
The issue is not seen if I use the same video file, copy to a device (e.g. Samsung Galaxy Note3/4) and then watch the movie locally on the device. The issue is not reproduceable on iPhone, iPad or AppleTV4 devices. If I use a media file with external .srt subtitles, it works fine across all devices.
To reproduce the issue:
  1. Start Plex App on a device
  2. Connect to a Server, if not already connected
  3. Select a movie shared by the Server
  4. Choose subtitles
  5. start the movie
Any ideas what could be wrong?
Example of a media file, encoded by NoteBurner, with this issue:
Media
Video Resolution 1080p
Duration 1:57:05
Bitrate 5607 kbps
Width 1916
Height 1032
Aspect Ratio 1.85
Container MP4
Video Frame Rate 24p
Web Optimized Nej
Has 64bit Offsets 1
Video Profile high
Del
Duration 1:57:05
File Sample2.mp4
Size 4.59 GB
Container MP4
Has 64bit Offsets 1
Has Chapter Text Stream 1
Has Thumbnail 1
Web Optimized Nej
Video Profile high
Codec H264
Bitrate 5090 kbps
Språk English
Bit Depth 8
CABAC true
Chroma Subsampling 4:2:0
Color Range tv
Color Space bt709
Duration 1:57:04
Frame Rate 23.976 fps
Frame Rate Mode vfr
Height 1032
Level 4.0
Pixel Format yuv420p
Profile high
Ref Frames 4
Scan Type progressive
Stream Identifier 3
Width 1916
Codec AAC
Kanaler Stereo
Bitrate 126 kbps
Språk English
Audio Channel Layout stereo
Bitrate Mode VBR
Duration 1:57:04
Profile lc
Sampling Rate 48000 Hz
Stream Identifier 1
Codec AC3
Kanaler 5.1
Bitrate 384 kbps
Språk English
Audio Channel Layout 5.1(side)
Bit Depth 16
Bitrate Mode CBR
Dialog Norm -27 dB
Duration 1:57:05
Stream Identifier 2
Codec TX3G
Språk English
Format TX3G
Stream Identifier 4
Codec TX3G
Språk Español
Format TX3G
Stream Identifier 5
Codec TX3G
Språk Nederlands
Format TX3G
Stream Identifier 6
Codec TX3G
Språk Svenska
Format TX3G
Stream Identifier 7
Codec TX3G
Språk Norsk
Format TX3G
Stream Identifier 8
Codec TX3G
Språk Dansk
Format TX3G
Stream Identifier 9
Codec TX3G
Språk Suomi
Format TX3G
Stream Identifier 10
Codec TX3G
Språk Ελληνικά
Format TX3G
Stream Identifier 11
Codec TX3G
Språk polski
Format TX3G
Stream Identifier 12
Codec TX3G
Språk Türkçe
Format TX3G
Stream Identifier 13
Codec TX3G
Språk العربية
Format TX3G
Stream Identifier 14
Codec TX3G
Språk עברית
Format TX3G
Stream Identifier 15
Codec TX3G
Språk українська
Format TX3G
Stream Identifier 16
Codec TX3G
Språk Česky
Format TX3G
Stream Identifier 17
Codec EIA-608
Språk English
Format EIA-608
Stream Identifier 18
Did you ever figure out how to fix this? I am seeing the same behavior with my Samsung TV.
I seem to recall that this has been discussed before - the MP4 format doesn’t officially support embedded subtitles. If you want to use embedded subtitles then you may find that you need to use an MKV format container instead.
Fortunately you can switch containers without re-encoding, ffmpeg will allow you to do this - see the last example here:
ffmpeg -i input.mp4 -map 0 -c copy output.mkv
Nope, you are mistaken. The TX3G format is even a specialty of mp4.
@Keo AFAIK the issue with TX3G subtitles is known and will be fixed in a future PMS version with an updated transcoder.
Until then, you can try to extract the chosen subtitle with mp4box. It gets written into a SRT file, which you can place beside the mp4 file.
https://forums.plex.tv/discussion/comment/1276734/#Comment_1276734
ok, let’s wait for a future PMS release…
so… I have been waiting for an update on this. Has anyone heard anything? Have been testing on all Plex Servers ad App release to date. Still same issue…
Any Plex Ninja available to check this?
