I cant SSH into 2.17 either… had a 1.x pmp embedded for Pi2 working before and did a fresh install of 2.17 and it boots… get to settings and turn on SSH but it refuses all passwords…
what are the currrent passwords/proceedures for SSH and wifi/conman setup
you know … after a couple years work now… you think that you could at least have all system setting in GUI like openpht/rasplex…
Are you making a SSH connection to the same IP/hostname? If so you may need to clear out the old keys on that computer initiating the SSH connection to the RPi.
I opened the CF card on my mac… edited the config file to boot up into shell
then setup connmand manually by creating a /storage/.cache/connmand settings file for my wifi ssd then manually connecting
funny thing is that when I boot the pi on wifi, I can now ssh into it wirelessly … very weird
still can’t update from within the embedded settings panel? I loaded 2.10 to see if it was a regression … looks like I will have to wipe it again and install 2.17 manually and set all this up again from scratch…
this really is bassackwards since rasplex has had a front end for system settings for YEARS…
this PMP embedded still screams amateur hour / hobby project… actually since rasplex is someones hobby and its more polished… that is an insult to good hobby programmers…
Hello markus101;
FYI, it seems that 2.17 may be broken vis a vis Alsa. I get nil when trying to detect the HiFiberry card (aplay -l gives no sound cards found. The team at Hifiberry sent me a Raspbian that does boot the PiB3+ and has the Amp2 card visible in Alsa (aplay -l shows the card)…
…but then I’m at a dead-end with respect to adding PMP to Raspbian. Thoughts? Help?
don’t make me buy another roku, I love my PMP embedded nuc… but wheres the DVR and other cool bits and pieces that have been added to all the other players???
+1 for an Update!!
In the next few days, we are going to bump the version of libcec in the LibreELEC build to a version beyond what’s in 8.2.5. In our internal testing, this appears to stop automatic tuning to the PMP device after the TV is turned on for those with LG TVs.
Confirmed 2.25.0.948-77f379e1 is working flawlessly on RPi 3B+. Once initial config is done, everything works as expected (WiFi setup still requires CLI config and timezone offset needed a script to persist across boots). Not sure if it’s just me, but all of the menus and animations feel way more responsive too.
Drop PlexMediaPlayer-2.25.0.948-77f379e1.Generic-x86_64.tar or PlexMediaPlayer-2.25.0.948-77f379e1.RPi2-arm.tar respectively into the Update share of the embedded appliance.
For Windows, use Windows File Explorer for the UNC path: \\plexmediaplayer\Update or \\ip-address-of-your-embedded-machine\Update
For MacOS, use Command+K and enter the server address: smb://plexmediaplayer/Update or smb://ip-address-of-your-embedded-machine/Update
