Would it be possible to get a better layout for Media Info?
When looking at my duplicates I like to compare the Media Info for each file.
Right now, it is hard to get a side by side comparison for each file. Listing each files info on top of each other makes it difficult to compare.
If each file was in its own column, then you could do an easier/quicker comparison.
Also, in doing a side by side, there may be instances where one file has info while the other doesn’t. If one file doesn’t have any info for that particular row, then just leave that block blank. This will help with comparison and keeping similar information on each row.
Just a thought and would be helpful.
