every time i use the MEDIA info to check the difference between files i have its a nightmare.
when you click on the 3 small dot next to the option of the file you get a dropdown menu, at the bottom of it you have “GET INFO”
and when you do click on it you get a small windows that you are supposed to read to see the difference if you have multiple file with the same name…but why ?
it makes it impossible to compare file that are duplicate, why don’t you have them side by side ? when i need to check something to see a difference i need to navigate up and down and remember what i read, its a nightmare of interface, i would hope this can be change and fix
