Enhanced Player for Specific Videos
Hello,
Please, could you modify the Enhanced Player enabled setting to allow it to be file/title specific?
For example, enable the EP for a specific video file or even a folder like an entire TV series.
I have a handful of files that won’t direct play without the EP enabled, but the EP seems to cause lag issues periodically on files that don’t require it. Being able to set a series or file to use the EP in the settings means I’d only have to do it one time instead of toggle on and off as needed.
Perhaps something like in Settings is where the “Default” settings would be and all files use the default unless changed in the settings for the specific title.
Thank you for the consideration.
Would you mind sharing some details on the videos that give you trouble in combination with the enhanced player? – e.g. using the XML info of that video (only the technical information between <Media> and </Media> are relevant)
https://support.plex.tv/articles/201998867-investigate-media-information-and-formats/
Also… what platform are we talking about? There’s a number of previews / betas with enhanced players – I’m aware of at least those on iOS/tvOS and Android (TV) :wink:
