"Enhanced Player" black spinning screen only audio
Server Version#: 4.87.2
Player Version#: 8.13
I have a lot of issues with the “Enhanced Player” on my Apple TV. I am currently having the issue with some media files not displaying any video and only audio while only a spinner is showing on the screen. It does not happen with all files.
mediainfo:
General
Unique ID                                : 193812156484959941017761799836060694910 (0x91CEDD13522C6B481F472207591D397E)
Complete name                            : /mnt/All Media/TV Shows/Lucifer/Season 1/S01E06 Favorite Son.mkv
Format                                   : Matroska
Format version                           : Version 4
File size                                : 711 MiB
Duration                                 : 43 min 36 s
Overall bit rate                         : 2 280 kb/s
Writing application                      : Lavf57.25.100
Writing library                          : Lavf57.25.100
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main@L4@Main
Codec ID                                 : V_MPEGH/ISO/HEVC
Bit rate                                 : 9 242 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Variable
Frame rate                               : 23.976 FPS
Original frame rate                      : 25.000 FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.186
Stream size                              : 2.82 GiB
Writing library                          : x265 2.0+1-6a9b6a828f79:[Linux][GCC 5.4.0][64 bit] 8bit
Encoding settings                        : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rskip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=250 / min-keyint=25 / scenecut=40 / rc-lookahead=20 / lookahead-slices=6 / bframes=4 / bframe-bias=0 / b-adapt=2 / ref=3 / limit-refs=3 / no-limit-modes / weightp / no-weightb / aq-mode=1 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=2.00 / rdoq-level=0 / psy-rdoq=0.00 / no-rd-refine / signhide / deblock=0:0 / sao / no-sao-non-deblock / b-pyramid / cutree / no-intra-refresh / rc=abr / bitrate=1984 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / ipratio=1.40 / pbratio=1.30
Default                                  : Yes
Forced                                   : No
Audio
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Commercial name                          : Dolby Digital
Codec ID                                 : A_AC3
Bit rate mode                            : Constant
Bit rate                                 : 384 kb/s
Channel(s)                               : 6 channels
Channel layout                           : L R C LFE Ls Rs
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Bit depth                                : 32 bits
Compression mode                         : Lossy
Stream size                              : 471 MiB (66%)
Writing library                          : Lavc57.24.102 ac3
Language                                 : English
Service kind                             : Complete Main
Default                                  : Yes
Forced                                   : No
Text
Format                                   : ASS
Codec ID                                 : S_TEXT/ASS
Codec ID/Info                            : Advanced Sub Station Alpha
Duration                                 : 42 min 54 s
Bit rate                                 : 89 b/s
Count of elements                        : 964
Compression mode                         : Lossless
Stream size                              : 28.2 KiB (0%)
Writing library                          : Lavc57.48.101 ssa
Language                                 : English
Default                                  : No
Forced                                   : No
Menu
00:00:00.000                             : :00:00:00.000
00:09:11.134                             : :00:09:11.134
00:16:02.712                             : :00:16:02.712
00:24:47.236                             : :00:24:47.236
00:30:10.684                             : :00:30:10.684
00:35:50.690                             : :00:35:50.690
00:42:57.992                             : :00:42:57.992
Logs:
logging-3.zip (1.1 MB)
@anon18523487 do you have any ideas or know who could / if this is a known issue?
I’m not personally aware of any issues like this. I do see something odd that could be contributing. The video has variable frame rates. I’m not positive on the Apple TV but it may not like VFR. Check if this is common among the files that don’t work for you.
Hmmm no unfortunately not. I just checked a file I have and its
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
FWIW these files work 100% fine in the old media player, just not the “enhanced” one. As soon as I revert it plays fine.
Ok, can you create me a small 20MB sample file. Make sure this fails.
Hello- sorry for the delay i have been out of town for the last few weeks. Here is a new file that I just tried to play and is doing it with the enhanced player again
sample.zip (19.9 MB)
Hello, @anon18523487 - just wanted to circle back here on this issue. Thanks!
Sorry, missed you update with the sample. I’m grabbing them now.
That video works fine for me. Did you test to make sure it fails for you?
Yeah- I waited until I organically came across one that failed and grabbed a sample from it.
Right, but did you try the sample?
Hey @anon18523487
Sorry, No, I did not. I am running into the issue again with a different file.
General
Unique ID                                : 121847269387182694572057497636933831051 (0x5BAAEE33A3C38EEEC031866DC80D898B)
Complete name                            : /mnt/All Media/Movies/Murder Mystery (2019)/Murder Mystery (2019).mkv
Format                                   : Matroska
File size                                : 10.4 GiB
Duration                                 : 1 h 37 min
Overall bit rate                         : 15.3 Mb/s
Encoded date                             : UTC 2022-01-04 08:00:00
Writing application                      : mkvmerge v63.0.0 ('Everything') 64-bit
Writing library                          : libebml v1.4.2 + libmatroska v1.6.4
Video
Format                                   : HEVC
Format profile                           : Main 10@L5@Main
HDR format                               : SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 14.3 Mb/s
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Frame rate                               : 24.000 FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.072
Stream size                              : 9.78 GiB (94%)
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : Display P3
Mastering display luminance              : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 1115 cd/m2
Maximum Frame-Average Light Level        : 167 cd/m2
Audio
Format                                   : E-AC-3
Format/Info                              : Enhanced AC-3
Commercial name                          : Dolby Digital Plus
Codec ID                                 : A_EAC3
Bit rate                                 : 640 kb/s
Stream size                              : 448 MiB (4%)
Language                                 : English
Default                                  : Yes
Forced                                   : No
Text #1
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Title                                    : [CC]
Language                                 : English
Default                                  : No
Forced                                   : No
Text #2
Format                                   : UTF-8
Language                                 : Arabic
Default                                  : No
Forced                                   : No
Text #3
Format                                   : UTF-8
Language                                 : Czech
Default                                  : No
Forced                                   : No
Text #4
Format                                   : UTF-8
Language                                 : Danish
Default                                  : No
Forced                                   : No
Text #5
Format                                   : UTF-8
Language                                 : German
Default                                  : No
Forced                                   : No
Text #6
Format                                   : UTF-8
Language                                 : Greek
Default                                  : No
Forced                                   : No
Text #7
Format                                   : UTF-8
Language                                 : Spanish
Default                                  : No
Forced                                   : No
Text #8
Format                                   : UTF-8
Title                                    : European
Language                                 : Spanish
Default                                  : No
Forced                                   : No
Text #9
Format                                   : UTF-8
Language                                 : Finnish
Default                                  : No
Forced                                   : No
Text #10
Format                                   : UTF-8
Language                                 : French
Default                                  : No
Forced                                   : No
Text #11
Format                                   : UTF-8
Language                                 : Hebrew
Default                                  : No
Forced                                   : No
Text #12
Format                                   : UTF-8
Language                                 : Hindi
Default                                  : No
Forced                                   : No
Text #13
Format                                   : UTF-8
Language                                 : Croatian
Default                                  : No
Forced                                   : No
Text #14
Format                                   : UTF-8
Language                                 : Hungarian
Default                                  : No
Forced                                   : No
Text #15
Format                                   : UTF-8
Language                                 : Indonesian
Default                                  : No
Forced                                   : No
Text #16
Format                                   : UTF-8
Language                                 : Italian
Default                                  : No
Forced                                   : No
Text #17
Format                                   : UTF-8
Language                                 : Japanese
Default                                  : No
Forced                                   : No
Text #18
Format                                   : UTF-8
Language                                 : Korean
Default                                  : No
Forced                                   : No
Text #19
Format                                   : UTF-8
Language                                 : Malay
Default                                  : No
Forced                                   : No
Text #20
Format                                   : UTF-8
Language                                 : Norwegian Bokmal
Default                                  : No
Forced                                   : No
Text #21
Format                                   : UTF-8
Language                                 : Dutch
Default                                  : No
Forced                                   : No
Text #22
Format                                   : UTF-8
Language                                 : Polish
Default                                  : No
Forced                                   : No
Text #23
Format                                   : UTF-8
Language                                 : Portuguese
Default                                  : No
Forced                                   : No
Text #24
Format                                   : UTF-8
Title                                    : Brazilian
Default                                  : No
Forced                                   : No
Text #25
Format                                   : UTF-8
Language                                 : Romanian
Default                                  : No
Forced                                   : No
Text #26
Format                                   : UTF-8
Language                                 : Russian
Default                                  : No
Forced                                   : No
Text #27
Format                                   : UTF-8
Language                                 : Swedish
Default                                  : No
Forced                                   : No
Text #28
Format                                   : UTF-8
Language                                 : Thai
Default                                  : No
Forced                                   : No
Text #29
Format                                   : UTF-8
Language                                 : Turkish
Default                                  : No
Forced                                   : No
Text #30
Format                                   : UTF-8
Language                                 : Ukrainian
Default                                  : No
Forced                                   : No
Text #31
Format                                   : UTF-8
Language                                 : Vietnamese
Default                                  : No
Forced                                   : No
Text #32
Format                                   : UTF-8
Title                                    : Simplified
Language                                 : Chinese
Default                                  : No
Forced                                   : No
Text #33
Format                                   : UTF-8
Title                                    : Traditional
Language                                 : Chinese
Default                                  : No
Forced                                   : No
This one I created a sample:
dd if=/mnt/All\ Media/Movies/Murder\ Mystery\ \(2019\)/Murder\ Mystery\ \(2019\).mkv of=sample.mkv bs=1M count=50
and moved the sample file into my media folders, Plex picked it up, I tried to play and it fails.
Here are new logs from both the server and the client and the sample file which triggered the issue: archive.zip
Could you try that file and let me know if that reproduces the issue for you? I did it 4/5 times just to be extra sure
I manually remuxed the file from MKV to MP4 and turned off the enhanced player and the video works perfectly fine. But i don’t think that should be necessary.
Huh. The sample reads as 71 kbps. That’s not right. It does play for me, but at about half the frame rate so something is definitely off. I don’t know if the file is just encoded badly or if there is an actual problem. I’ll investigate some more.
This happens pretty frequently with HEVC files I’ve noticed, I have another one doing it right now. Did you happen to ever find anything? I have lots of complaints and they pretty much always have to do with HEVC content.
Running into this issue again, I don’t think it is the file. It’s many different files that have this issue.
Hey @anon18523487- would another sample help? I have several videos with this issue.
No, but can you provide me the xml info from your server for some of these files.
murdermystery.html.zip (14.7 KB)
