Enigma recordings on chromecast fail to play
Hi, I have a strange issues with my TV recordings made by an Enigma2 decoder (Zgemmah7s). If I play these recordings via ios devices they play fine, but when I try to play with my chromecast the bottom part of the screen gets scrambled.
If I type mediainfo on the file I get this output:
General
Complete name                            : /srv/5e116b03-d9a3-4e7d-b2c4-d128c7d0fee2/movie/20200207 2110 - LA7 HD - Propaganda Live.ts
Format                                   : MPEG-TS
File size                                : 12.3 GiB
Duration                                 : 4 h 4 min
Overall bit rate mode                    : Variable
Overall bit rate                         : 7 209 kb/s
Video
Menu ID                                  : 751 (0x2EF)
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 4 frames
Format settings, GOP                     : M=4, N=32
Codec ID                                 : 27
Bit rate                                 : 6 659 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate                               : 25.000 FPS
Standard                                 : Component
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Interlaced
Scan type, store method                  : Separated fields
Scan order                               : Top Field First
Bits/(Pixel*Frame)                       : 0.128
Stream size                              : 11.4 GiB (92%)
Color range                              : Limited
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Audio
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Mode extension                           : CM (complete main)
Format settings, Endianness              : Big
Codec ID                                 : 6
Bit rate mode                            : Constant
Bit rate                                 : 192 kb/s
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 spf)
Bit depth                                : 16 bits
Compression mode                         : Lossy
Delay relative to video                  : -774 ms
Stream size                              : 336 MiB (3%)
Language                                 : Italian
Menu
List                                     : 1530 (0x5FA) (AVC) / 1532 (0x5FC) (AC-3, Italian) / 7312 (0x1C90) ()
Language                                 :  / Italian
Any idea why this is happening?
Server Version#: 1.18.7
