Enigma2 Box (ZGemma H9s) -> XTeVe -> Plex DVR
Hey Plex Gurus!
I am revisiting this whole setup, I am really hoping I can get this working - as it means i can use my satellite dish rather than a internal aerial. So best start with what i have done so far…
  1. Setup Zgemma Box with Whooshbuild
  2. Exported the Bouquet of a selection of the channels I want in Plex (called favourites)
  3. Extracted the .tar file and zipped it up as a .zip (using 7Zip)
  4. Used the tool here to create my m3u file.
  5. Moved m3u file into a simple directory on the Plex Server (c:\m3u\favs)
  6. Setup XTeVe (PMS mode) and entered the local address of the file (above)
  7. Plex recognises the XTeVe when using the IP and port of the server and builds guide
So, onto the problem(s):
  1. After Plex builds the guide and configures, it then shows as “device not found” when I go back into the DVR setup screen
  2. When I try and watch the channel that the Zgemma box is currently on from Plex, it works (happy days)…but when i select any other channel, it fails to stream (“Failed to tune to channel”) - It seems not to be able to change the channel on the tuner box.
I am so close with this, really hoping someone can help with this…feels like a checkbox or an option I have/have not selected.
Has anyone ever come across this and can help me retain my sanity? :wink:
