Enigma2 support for Plex DVR/LiveTV!
not sure what OpenATV are building, but IPTV is not in master branch.
Works really well for me on an old DM800HD after having flashed to newest OpenPLI.
@andyblac1974 i will post some pics in a few moments so you can see what i mean.
Do you use the IPTv test branch on your dm?
No, I don’t even know what that is :slight_smile:
@andyblac1974 ok so i was wrong, i looked under Bouquets. My bad. Now i have it installed without running the plugin after download and replaced the files in the specific folder. All Good, but after setting Tuner to Iptv and Bouquets to iptv, concurrent streams stays at 2, i save the settings but the plugin tells me that there is already another tuner setup and i need a second pms to added it?
EDIT: Sry i got it and saved a new file with iptv tuner all good now.
But PMS doesnt recognize my box? Do i need to do something else?
EDIT: OK i got it all working:)
@andyblac1974 really nice plugging. Keep up that good work. Donations on the way :slight_smile:
Using he IPTV Test branch on a DreamBox dm900uhd with OpenAtv 6 and it works very well :slight_smile: also for my second one with OpenPLI 6 :slight_smile:
Great Job
Thanks a lot
Great Job
Thanks a lot
glad you got it working :slight_smile:
Great Job
Thanks a lot
PMS recognised the Dreambox automatically but it stucks now at the program guide search :frowning:
for IPTV you will need to find your own EPG data. using XMLTV, I doubt plex will have the guide data for your IPTV provider.
ok thanks and without this file it will not work?
I have a subscription to Schedules Direct EGP. Any way I can use that since the Plex EPG is not loading for me.
@jamesdisco said:
@andyblac1974 said:
If anyone is interested I have created a test branch for IPTV support, would helpful if anyone that want IPTV support to test it and report any issues.
to use it open plugin, remove any previous setup by pressing YELLOW on that tuner type, and then go to IPTV tuner type, and setup, and remove old tuner from plex and re-add the new type.
source files here https://github.com/OpenViX/PlexDVRAPI/tree/iptv-test/PlexDVRAPI/src
Having a play with this and its working great both recording and live TV. am i able to setup my satellite channels to work at the same time or can we only do one type at once.
Hey there @jamesdisco ,
How did you get the XMLTV file to pass the DVR setup?
Thanks in advance
Thanks in advance
I didnt i just used the plex guide as it has all my IPTV channels in it. Its dead easy to to get plex to read your xmltv file just follow the instructions here and give it the location of your file.
Thanks in advance
Thanks for your reply :slight_smile:
Il will give it a try then thanks
Is there any way to get the plugin to look at Bouquet rather than all the channels. I have trimmed down my Bouquets to just the bare basics but when the plugin checks the receiver for channels it comes up with the whole list and presents them to Plex.
you need to update the latest version it support the option to choose which bouquet to use
I have installed the plugin on my H2S box and updated it with the iptv data. I now have the option to select iptv. However when I try to save the setup the box crashes. I have attached the log file showing the error message.
Can you help?
Can you help?
hi, I have just pushed a fix for that, please try new files, and let me know.
Thanks, I have applied the fix and I was able to select the iptv option and the box saved the data ok . However in Plex, I cant get past the epg part. If I let it search for epg data it sticks at 93%.
I think it is caused by the VOD section of the iptv???
Update, selected a single bouquet and it works. Stop starting, but maybe my laptop is not good enough as a server…
