@rockard said:
@andyblac1974 said:
@rockard said:
Hi again, it didn’t work (cannot be added in Plex), and I’ve been trying to figure it out. So it seems http://IP:6081 should return a json, but it returns 404 not found. So I tried to understand where the files should be created, and think I can see they should reside in /www, but there’s just three folders (two of which are symlinks) there: logs, pages and var. So I took a quick look at this commit: [HTTP Server] add new embedded HTTP SERVER, this removes the DEPEND o… · OpenViX/HRTunerProxy@1020f25 · GitHubIt says in server.py row 173 it says
if self.discover[type][“TunerCount”] > 1 and self.discover[type][‘NumChannels’] > 0:Should it not be self.discover[type][“TunerCount”] > 0 now that multi tuner is not required?
Best,
Rickardchanged that in the pyo’s I gave you. did it not work ?
edit:
what a fool I am YES, I missed one thanks, I’ll fix now.
I tried to figure out how to build it myself on my Linux box, but I didn’t get very far (installed automake debian package and typed automake, failed immediately on missing enigma2-plugins-config.h.in). Do you mind building it again for me?
/Rickard
the build is designed for OpenEmbeeded, you don’t need to build anyway, just take the PY’s copy then to box, restart E2, then delete all the PY’s and leave the PYO’s
Do you have any technical details on what was required for the Auto-Detection within Plex?
plex had and bug in there detection code, I got that fixed it is in 1.7.3 (don’t ask for eta I don’t know) , on the tuner box, you need to code a SSDP broadcast server.
@andyblac1974 thanks again for your great job.
I have some issue, I hope someone could help me.
Hardware:
Vu+ Solo SE 2
Software OpenVIX 5.0.016
Server:
Plex 1.7.2.3878 PlexPlass
I cannot Watch Live TV only Record(Aufnehmen). Some explanation? Also the Program Guide is not available on the APP Iphone and Apple TV.
Thanks.
BR
@ogret said:
@andyblac1974 thanks again for your great job.I have some issue, I hope someone could help me.
Hardware:
Vu+ Solo SE 2
Server:
Plex 1.7.2.3878 PlexPlassI cannot Watch Live TV only Record(Aufnehmen). Some explanation? Also the Program Guide is not available on the APP Iphone and Apple TV.
Thanks.
BR
From https://www.plex.tv/features/live-tv-dvr/:
“Plex Live TV is currently available on Android TV and iOS devices, but recorded TV shows and movies can be watched, wherever you go, on more mobile and home streaming devices than any other DVR solution, including iOS, Android, Windows, Mac, Linux, Roku, Chromecast, Amazon Fire, NVIDIA SHIELD and other Android TV devices, Apple TV, Xbox, PlayStation, and most Smart TVs.”
So make sure you have the latest version of the app on an Android TV or iOS device.
After reboot the Iphone and Plex Server it works. Thanks.
Apple TV is not IOS, thats TVOS, so not available yet for AppleTV, as for iPad it should work. Click on Browse bottom right corner of app, then you should see Program Guide.
@andyblac1974 said:
@FidoFuz said:
Do you have any technical details on what was required for the Auto-Detection within Plex?plex had and bug in there detection code, I got that fixed it is in 1.7.3 (don’t ask for eta I don’t know) , on the tuner box, you need to code a SSDP broadcast server.
I downloaded your plugin onto my zgemma boxes, is it just a matter of waiting until 1.7.3 is published??
only for the automatic detection of tuners.
otherwise you can manually enter the ip/port
I uploaded the plugin manually to my miraclebox (twin hd with openatv). When I get to the point where I press the green button to ‘create’, the box reboots itself. Is that normal? I can’t proceed to add the box to plex after that. It’s been a long time since I updated this box. Maybe that’s the issue?
System OE: OE-Alliance 3.2
Distro: openatv
Firmware version: 5.1.0
Driver date: 20150218
Kernel version: 3.6.0
Gui version: 2015-09-14
try with the latest ATV image, your using a very old image.
the plugin will be in the download section of the image.
V6 recommended? I tried 5.3 earlier and got the same.
yes 6.0 or 6.1 needed 5.3 to old
I updated to v6 and have the same issue as @stevilness i did notice an error on the screen saying
“www/cable” no such file or directory
yes issue was fixed today
create a Folder /www on root of your box
or wait Image next day have fix the issue
awesome. The same fix worked for me…rebooting now then time to see if the plex side if all working
Thanks for the effort here. Much appreciated.
np, any more issue let me know
works now with atv
https://www.opena.tv/plugins/35011-plexapi-dvr-plugin.html#post306319
@andyblac1974 said:
i have updated the plugin to allow it to work with 1 tuner, but a warning will show, that you must leave box in standby, else recordings/livetv will not work in Plex.
thank you! much appreciated. Will try it again ![]()
