first, in the setup there is a message that the VDR is not found, but is online and i have live tv on iOS.
second, there is no write access to the destination.
Is it a problem of the plugin?
1st is known bug, I think it is just cosmetic, plex some times, forgets about the device, but should still be working,
2nd make sure the user plex has privileges to the share/folder of your library.
Seems to work out of the box now. Thanks! However the channel selection to the EPG provider is a pain in the but. How do I change that? Suppose I misclicked during the setup and want to change the EPG channel for the enigma channel… How without having to completely kill the DVR and reinstall?
Other than that: GREAT PLUGIN! Thanks so much!
Settings → Server → DVR (Beta) → Click “YY enabled” in “XX channels - YY enabled”
If it says it’s “Device not found”, restart PMS and “XX channels - YY enabled” should show up.
We can argue whether or not to use enigmas data… But for Germany it was a pain in the butt to match the channels to the Telekom driven EPGs. A lot of guesswork and some channels simply to not seam to exist in the Telekom EPG data…
