@plexip said:
Be happy that we have people like andyblac1974 they wrote a plugin for Enigma2 boxes and you can use it with Plex DVR
“Normally” the big advantage in Plex DVR -among others- is the EPG from Gracenote. Today it is not complete but it grows over time. If we miss a channel in a specific provider list we can tell it Plex.
The other way is a XMLTV file, which you have to provide to your Plex DVR server. Use tools like WebGrabPlus for that.
Tried WebGrab++ and it runs now on my Synology… so far so good and a good idea to get the latest epg files. But I noticed that I don’t get “posters” in the EPG-View in Plex, only empty placeholders. Description is there but no posters for the events. What I’m I doing wrong or do I need another tool for the posters?
hello and a big thank you for this but I need a little help please
I’ve downloaded PlexDVRAPI.zip unzipped it and transferred it to
usr/lib/enigma2/python/Plugins/SystemPlugins/PlexDVRAPI
on my zgemma 2s running wooshbuild v5 (v6 is not available for 2s)
I go to plugins after reboot and can see the Plex DVR api for enigma2
it shows http://192.168.1.146:6083 I’ve forwarded this in my router as well
but plex gives me an error: There was a problem adding the device: http://192.168.1.146:6083
any ideas where I’m going wrong ?
TIA
no need to forward in router, what version of PMS are you running ?
Have you created the api files (?) as described in the instructions. I believe: install, reboot, enter the plugin, create the api files (green?), reboot.
no sorry I hadn’t but I’ve just tried it and got a
really sorry your receiver encounter a software problem and needs to reboot message with a lot of text
and then reboots, I’m not sure how to find the log file on the box
It says that /www/satellite is missing. Try creating it… I did not need to but others also said /www had to be created. Are you sure you are using the latest GitHub version?
No its from page 2 of this thread, I did try github but I’m not sure which part of the zip I downloaded to add to the box, I’ll give it another go tomorrow from the github zip, thanks for everyone’s help and patience
Hi @andyblac1974 and thanks for the good work. I’m going to ask them to consider your requests. In the meanwhile, can I add it manually to my OpenPli plugins or not?
openpli already included plexdvrapi, into their next version, which is OpenPLi 5 I think.
