Server Version#: 1.22.0.4157 Mac
Not sure when this started happening but I am no longer getting EPG data which leads to no live tv functionality. Each time I try to manually update the guide, it gets so far and stops with the following messages in the log file
Any suggestions would be appreciated.
Mar 08, 2021 09:29:54.733 [0x70000179b000] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Mar 08, 2021 09:29:54.735 [0x70000179b000] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Mar 08, 2021 09:29:54.742 [0x70000179b000] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Mar 08, 2021 09:29:54.744 [0x70000179b000] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Mar 08, 2021 09:29:54.746 [0x70000179b000] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Mar 08, 2021 09:29:54.749 [0x70000179b000] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Mar 08, 2021 09:32:30.034 [0x70000179b000] ERROR - SQLITE3:(nil), 1, statement aborts at 172: [insert into metadata_items (library_section_id,parent_id,metadata_type,guid,hash,media_item_count,title,title_sort,original_title,studio,rating,audience_rating,rating_count,tagline,su
Mar 08, 2021 09:32:30.034 [0x70000179b000] ERROR - Exception inside transaction (inside=1) (…/Library/MetadataItem.cpp:1142): sqlite3_statement_backend::loadOne: SQL logic error
Mar 08, 2021 09:32:30.034 [0x70000179b000] ERROR - Exception inside transaction (inside=1) (…/MediaProviders/EPG/Cloud/MediaProviderEpgCloud.cpp:140): sqlite3_statement_backend::loadOne: SQL logic error
Mar 08, 2021 09:32:30.038 [0x70000179b000] ERROR - EPG[cloud]: Caught exception during data chunk load: sqlite3_statement_backend::loadOne: SQL logic error
Mar 08, 2021 09:32:46.270 [0x700001718000] WARN - SLOW QUERY: It took 310.000000 ms to retrieve 50 items.
Mar 08, 2021 09:32:55.993 [0x70000179b000] ERROR - SQLITE3:(nil), 1, statement aborts at 174: [insert into metadata_items (library_section_id,parent_id,metadata_type,guid,hash,media_item_count,title,title_sort,original_title,studio,rating,audience_rating,rating_count,tagline,su
Mar 08, 2021 09:32:55.993 [0x70000179b000] ERROR - Exception inside transaction (inside=1) (…/Library/MetadataItem.cpp:1142): sqlite3_statement_backend::loadOne: SQL logic error
Mar 08, 2021 09:32:55.993 [0x70000179b000] ERROR - Exception inside transaction (inside=1) (…/MediaProviders/EPG/Cloud/MediaProviderEpgCloud.cpp:140): sqlite3_statement_backend::loadOne: SQL logic error
Mar 08, 2021 09:32:55.998 [0x70000179b000] ERROR - EPG[cloud]: Caught exception during data chunk load: sqlite3_statement_backend::loadOne: SQL logic error
Mar 08, 2021 09:32:55.999 [0x70000179b000] WARN - EPG[cloud]: Failed to load EPG.
