My EPG has not been updating in the maintenance cycle. In the “Plex Media Server.1.log” file, I see the following error.
Mar 30, 2018 04:47:22.686 [14776] ERROR - EPG: JSON parse error. Data from request is
Mar 30, 2018 04:47:22.686 [14776] WARN - EPG[onconnect]: Failed to load EPG.
I can refresh it manually and it works. I have attached my logs so you can see the entire error.
<title>Access denied | tmsapi.plex.tv used Cloudflare to restrict access</title>
<h2 class="cf-subheadline">You are being rate limited</h2>
<p>The owner of this website (tmsapi.plex.tv) has banned you temporarily from accessing this website.</p>
Plex Media Server version 1.12.3.4947 has just been released as beta
It has a fix for caching bug where the cache was not correctly checked before making EPG requests to tmsapi.plex.tv. With this fix, the volume of requests should reduce significantly - 75% reduction has been observed. This should avoid getting Cloudflare rate limiting temporary IP Bans.
The hotfix release for the bug giving rise to lost airings and recordings between 00:00 and 01:00 GMT on the day the EPG is refreshed is now available as beta release 1.12.3.4973-215c28d86
See Release Note
(DVR) Keep airings in US primetime from disappearing from the schedule on each refresh (#8448)
