EPG not automatically updating
I keep having to manually force a guide refresh every week or so as it doesn’t seem to ever do it automatically. I’ve had the JSON parse error in the past but in those cases a manual refresh would not work either. Seems like it just never triggers?
<title>Access denied | tmsapi.plex.tv used Cloudflare to restrict access</title>
        <h2 class="cf-subheadline">You are being rate limited</h2>
            <p>The owner of this website (tmsapi.plex.tv) has banned you temporarily from accessing this website.</p>
Plex Media Server version 1.12.3.4947 has just been released as beta
It has a fix for caching bug where the cache was not correctly checked before making EPG requests to tmsapi.plex.tv. With this fix, the volume of requests should reduce significantly - 75% reduction has been observed. This should avoid getting Cloudflare rate limiting temporary IP Bans.
See Release Note http://forums.plex.tv/discussion/comment/1650553/#Comment_1650553
  • (DVR) HTTP request cache should properly check for file expiration when requesting celeb/series data. (#8405)
Thanks I’ll be trying that!
Would like to mention here an EPG related hot fix
The hot fix release for the bug giving rise to lost airings and recordings between 00:00 and 01:00 GMT on the day the EPG is refreshed is now available as beta release 1.12.3.4973-215c28d86
See Release Note
  • (DVR) Keep airings in US primetime from disappearing from the schedule on each refresh (#8448)
