EPG issues
Have HDHomeRun Prime, PMS on Win 10, and client on nVidia Shield TV.
  1. EPG shows channels which I do not have. On PMS when I add the DVR and it shows the channels you have, they are all numbered but some of the channels aren’t there because they’re not part of your subscription (Comcast). So for example channel ‘32’ is missing. However in the client, that channel will show up, won’t have a preview image and when you try to play it just gives an error. Is there a way to not show these channels in the EPG?
  2. My DVR has about 372 channels. I only set it up yesterday and all channels were visible in the client. This morning when I turned on Plex only 63 channels were showing when browsing programs. In PMS it still showed 372 channels, but even the web client in PMS only showed 63 channels. I had to delete DVR and re-add it to get the channels back.
  3. With 372 channels, it would be great to organize these in to favorites, or search for a particular channel. Scrolling through the channels is not an efficient way to find a channel.
